Author Topic: About multiple interrupt ISR (PIC)  (Read 6063 times)
Offline danielksTopic starter
  • Country: my
  • Newbie from Malaysia
« on: October 24, 2011, 04:49:53 pm »
Can anyone teach me how to write the coding for Interrupt polling type in Hi-tech C ?
For example Timer Interrupt and CCP interrupt together...  :'(
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: About multiple interrupt ISR (PIC)
« Reply #1 on: October 24, 2011, 08:12:42 pm »
loop:
   if (PIR1[CCP1IF]) doMe();
   if (PIR1[TMR1IF]) doYou();
goto loop;
something like that?
  • Country: my
« Reply #2 on: October 25, 2011, 05:01:31 am »
Now I have a coding which consist of 5 interrupts in the ISR. But i only try with 1 timer interrupt and 1 CCP interrupt. I set the timer interrupt priority to high and CCP to low but when ever CCP interrupt happen, the program hang. if I set more than 1 CCP interrupt non of the interrupt will works and program Hang.
  • Country: my
« Reply #3 on: October 25, 2011, 01:41:35 pm »
your code pls? ... this topic should be moved to microcontroller section.
  • Country: my
« Reply #4 on: October 25, 2011, 02:25:36 pm »
sorry about that..  :-[
my coding..
void interrupt ISR()
      if(TMR0IE==1&&TMR0IF==1)
            t++;            //increase counter by 1
            if(t<s1){
               motor1=1;
            if(t<s2){
               motor2=1;
            if(t<s3){
               motor3=1;
            if(t<s4){
               motor4=1;
            if(t==s1){
               motor1=0;
            if(t==s2){
               motor2=0;
            if(t==s3){
               motor3=0;
            if(t==s4){
               motor4=0;
            if(t==1000) //Reset counter to 0
               t=0;
         TMR0IF=0;  //Reset interrupt flag to 0
         TMR0=250;
if (CCP4IE==1&&CCP4IF==1)
   count1++;
   CCP4IF=0;
      if (count1==1)
         t1=TMR1;
         count1==1;
         CCP4CON=0b00000100;     //falling edge detection
      if (count1==2)
         t2=TMR1;
         count1=0;
         CCP4CON=0b00000101;   //rising edge detection
         TMR1=0;
   if(CCP5IE==1 && CCP5IF==1)
   count++;
   CCP5IF=0;
      if (count==1)
         t11=TMR1;
         count==1;
         CCP5CON=0b00000100;     //falling edge detection
      if (count==2)
         t22=TMR1;
         count=0;
         CCP5CON=0b00000101;   //rising edge detection
         TMR1=0;
With the CCP5 interrupt in the coding just wont run. it hangs.
  • Country: my
« Reply #5 on: October 25, 2011, 06:14:12 pm »
first you put ambiguity to the compiler... CCP5IE==1 && CCP5IF==1 could be...
((CCP5IE==1) && CCP5IF)==1
(CCP5IE==(1 && CCP5IF))==1
CCP5IE==((1 && CCP5IF)==1)
this semantics ambiguity is very hard to acertain. maybe there's operator's presedence that make it right, but its safer practice to clearly state what you want, ie i think it should be... if ((CCP5IE==1) && (CCP5IF==1)), note the bracketting.
second... whats this? 4th line (arrowed)? i cannot compile that. i dont think thats necessary.
if (count==1)
t11=TMR1;
count==1;     //      <---------------- ????????????
i cannot trace the hanging procedure, try clearing up your code as stated above and see if its working.
