thought some of you guys might be interested to see the insides of a high current compression connection... these cross section photos are of a 2/0 compression lug i crimped some time back.
cable: 00AWG (2/0, 133kcmil) carolprene welding cable. 1248 30awg strands. EPDM jacket
lug: t&b black 45 double band
die: t&b black 45 hex
hydraulic psi: 10,000
output force: 14-tons
pics 1 & 2 show the barrel end of the severed lug as i found it in my yard nearly a month after it was removed. pic 3 was after cutting with a dremel followed by cleaning up with a grinder. pics 4-6 show the cross-section after sanding smooth followed by a quick polishing. enjoy!
-sj
