The datasheet should specify absolute maximum rating on the input pins, but it doesn't.
There is only a simplified diagram, figure 1 on page 18.
It looks like you can't exceed V+ because the input is clamped by a diode. As long as you stay below V+, this diode is not a problem. There is a maximum input current rating of 20mA, which may refer to the maximum current this diode can take. There is also note 3: "this parameter is not tested"
Then there is 5.7kΩ resistor to an internal PNP. The PNP is either of a type that can withstand many volts of reverse base-emitter voltage, or of a type that can't. If it can, no problem. If it can't, it could (and should) be protected by a diode between the base and emitter. Either way, 36V maximum differential input voltage is specified, so this issue ought to be sorted out one way or another.
Nothing else is shown on the diagram which could possibly cause problems.
My bet is that you are safe. But encountering this chip myself would tempt me to see how much hassle it is to contact Linear Devices support and ask for clarification...
