Thanks for those measurements,
mzzj. Can you clarify if the Abiko terminals that measure 5.8 mm OD are "quick disconnect" or just ring/spade? I ask because Abiko appears to make the various Molex crimpers that are required across these different diameters. It'd be interesting to know if Abiko has the same such variation among their own terminals. (Compare Abiko's KSAC0760 with Molex's 64001-0100, -200, and -400. Looks identical to me, save for the dies. All are made in Sweden, too.)
After researching the crimp die dimensions among Molex, Panduit, and TE, I came up with a compromise without having to buy a bunch of dedicated tools. I'll use my KNIPEX crimper for Molex Insulkrimp ring, spade, and splices, as its die geometry matches the
Molex 64001-0100 application spec [PDF]. For the quick disconnect terminals, I picked up a used
AMP/TE 59824-1 crimper which is supposedly compatible with all insulated TE FASTON terminals, as well as some of their other PIDG and PLASTI-GRIP terminals and splices. The AMP tool
may also work with a few Panduit terminals that specify their
CT-1525 tool, notably the nylon DNFR-B insulated flag terminals (those are nice because they have an extended crimp barrel and don't require a dedicated flag terminal crimping tool).
One could probably make a full-time job out of understanding the application guidelines for crimp terminals! I can report back when I receive the AMP crimper and new terminals. In the meantime, I'd still be interested in hearing any input and experiences from you all.
