Author Topic: Prototyping component holder  (Read 1248 times)
Offline cowasakiTopic starter
« on: February 29, 2020, 09:50:56 am »
I'm looking for ideas for some kind of holder for components. such as caps and resistors.  I'm building a valve amplifier experimentation kit for the 3D printer so there will be equal sized blocks for 9 and 8 pin valves, tone stack, reverb unit etc etc.  For the tone stack you might wish to change the fixed resistor and or cap values.  I've sorted how I will do the pots.....
Any ideas?
Offline tautech
Re: Prototyping component holder
« Reply #1 on: February 29, 2020, 09:54:31 am »
Wiper style IC sockets ?
« Reply #2 on: February 29, 2020, 10:01:18 am »
Yes that was one idea as was headers like arduinos have.  I'm trying to find the best options.  I hope to produce lots of modules of a standard size (plus some half and double sized). So that you can quickly prototype a new valve amp design whilst keeping the dangerous voltages at bay.
Offline tautech
« Reply #3 on: February 29, 2020, 10:11:33 am »
You could probably blank every second hole off to give adequate separation but still components will be close together or go real agricultural and use screw terminal chocolate blocks.  :scared:
Then again there are mains push connectors but not sure if they're available in PCB mount.
Have a look at the Phoenix catalogue.
https://www.phoenixcontact.com/online/portal/nz?1dmy&urile=wcm:path:/nzen/web/main/products/entry_page/entry_page
« Reply #4 on: February 29, 2020, 10:22:37 am »
Thanks.  Not wanting things to be PCB mount.   Point to point will be ideal......  When I'm in valve mode I have to shun those horrible "circus boards".  I have to compartmentalise my electronics  :)
Offline ChristofferB
  • Chemistry phd student!
    • My channel:
« Reply #5 on: February 29, 2020, 02:18:45 pm »
What about IC sockets or tiny breadboards mounted on tube bases, fitting in additional tube sockets?
The component assemblies could then be put in cardboard/aluminium tubes for aesthetics, soldered into more rigourous plug-in modules free-wire or perf board or similar.
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
