mzzj, by the looks of those crimps, I bet my KNIPEX dies would work with these PIDG double-walled terminals. They measure about 5.7 mm on the OD, just a hair smaller than the 5.8 mm Abikos you described in Post #5. It looks like you're still getting that secure squashed/bulging effect on the insulation, even though the Abiko dies look quite a bit different than my TE/AMP tool.
2N3055, thanks for sharing the KNIPEX tool you're using. I bet the geometry is identical to my Crimp System. What brand of terminals do you prefer?
Gregg, do you have any issues with the insulation sleeving breaking with the dimple crimpers?
Interesting discussion on the dimple-type crimpers. I have the KNIPEX 97 49 14 dies (shown below) which are intended for non-insulated tubular terminals per DIN 46234 and 46235. These do not produce an F-crimp. I've used them on Molex Krimptite with success, but I think they might work best with brazed seam terminals due to the crimping forces involved (no splitting of the seam). Panduit, however, notes in their application guides that you can use either type of seam with their tool, just align the seam opposite the indentor. Any real world experience on that one?
