Hi to all,
thanks for answers,
I am in doubt because in data sheet for TC1165-5 is listed Vin Max 6V, Vin MIN 2.7V, output 5V.
I assume that output should be 5V in entire scale for Vin from 2.7 - 6V.
there are also other type of same LDO series with different output Voltages , 1.8V,3.3V...
they also mention that is for battery operated circuits.
is there any one of you can suggest circuit from experience that is working for 5V output,cca 100mA. with connected 3V batteries in serie.
Thanks.
