Author Topic: Interesting failure mode after potting  (Read 13370 times)
    • Mike's Electric Stuff
« on: March 06, 2014, 01:55:56 pm »
1 metre x 25mm PCB, 0.8mm thick, containing LEDs, driver chips and some passives, all SMD. Tested and known working.
It gets placed component-side down into a cavity in an aluminium mould, which is pre- filled with clear epoxy, and epoxy is brushed over the rear to cover the non-component side, to form a fully encapsulated strip, about 4mm thick. There are some captive wires emerging from one end.
After the epoxy has cured (24hrs at 25 deg.C), the strip is removed and re-tested.
On a few PCBs, one driver chip has died. Always the one nearest one end, but not the same end.
Failure mode is that a pin has low resistance to ground.
Depending on the end, this pin is either tracked to a pad very close to the end of the PCB, or connected via a 5k6 resistor to one of the flying leads.
I think I know what happenned - would be interested to see if anyone comes to the same conclusion before I explain my thoughts.
I do not believe it to be a mechanical issue.
Day Job: Mostly LEDs
Offline JuKu
    • LitePlacer - The Low Cost DIY Pick and Place Machine
Re: Interesting failure mode after potting
« Reply #1 on: March 06, 2014, 01:58:21 pm »
Without knowing the specifics, my guess is ESD.
http://www.liteplacer.com - The Low Cost DIY Pick and Place Machine
« Reply #2 on: March 06, 2014, 02:01:51 pm »
More specifically....? Something about the process....
Offline Nermash
« Reply #3 on: March 06, 2014, 02:06:11 pm »
Brushing the epoxy over ends?
« Reply #4 on: March 06, 2014, 02:07:31 pm »
May be a contributory factor, but I think possibly more fundamantal than that.
Offline nihilism
« Reply #5 on: March 06, 2014, 02:08:13 pm »
flux residue contamination
Offline Len
« Reply #6 on: March 06, 2014, 02:11:20 pm »
Static charge builds up, maybe because of the brushing, and when you remove the strip from the mould (picking up by one end or the other) it sparks to your finger.
DIY Eurorack Synth: https://lenp.net/synth/
jucole
  • Guest
« Reply #7 on: March 06, 2014, 02:19:31 pm »
Too much exothermic heat during the curing process?
Offline JuKu
« Reply #8 on: March 06, 2014, 02:20:14 pm »
About your ESD precautions. You might have done all that should be done and handle the potting "ESD-aware" manner, in which case guessing ESD is almost an insult. If not, the method sounds like a recipe for something like in your avatar picture in smaller scale...   :P
jucole
  • Guest
« Reply #9 on: March 06, 2014, 02:45:35 pm »
ES charge in the brush you used?
Online nctnico
« Reply #10 on: March 06, 2014, 02:57:51 pm »
Epoxy shrinks. It's a bad potting material especially for such a large PCB. Nowadays mostly PU based potting compounds are used.
Online Andy Watson
« Reply #11 on: March 06, 2014, 03:06:21 pm »
So, you're making a one metre long parallel plate capacitor with epoxy resin dielectric!  When you separate the plates, any voltage present (due to small amounts of charge being generated somewhere in the curing process) is magnified many times to maintain the C proportional to 1/d relationship, as in a Wimshurst machine. I guess the situation is exacerbated by levering and removing one end first.
« Last Edit: March 06, 2014, 03:15:24 pm by Andy Watson »
« Reply #12 on: March 06, 2014, 03:23:10 pm »
OK here's my theory.
The PCB and the mould form plates of a capacitor, the epoxy is the dielectric.
As it's liquid, the epoxy is contacting the mould extremely intimately, at the molecular level. There is also a mould-release compound, which may have some effect - I'm not a physicist or chemist but I imagine that a mould-release agent is probably using an electrostatic effect at the molecule level to repel the thing you don't want to stick.
The act of removing the now-solid piece of plastic from the mould induces a charge as electrons get ripped off at the boundary, so the PCB, which is now isolated inside the plastic, is sitting at a potentially high voltage, and due to its size, has enough capacitance to store significant energy.
Most of the time this would get discharged whne the groundplane edge, or ground wire during test gets grounded by contact,. but if the pad near the end of the PCB, which has minimal epoxy on it, or the non-ground wire touches something first, this discharges the stored charge through the IC pin.
The fact that it manages to do this via a 5K6 resistor suggests significant stored energy.
No rubbing is needed - I believe the act of peeling out of the mould is enough to create the charge.
Does this sound plausible? Any physicists here?
Offline Len
« Reply #13 on: March 06, 2014, 03:32:14 pm »
You've discovered the Leyden jar! :)
[Edit] Or the Loughton jar?
« Last Edit: March 06, 2014, 03:34:31 pm by Len »
Offline wiss
« Reply #14 on: March 06, 2014, 03:59:25 pm »
I used to have a DIY photo-lab where I bought film in 30 m rolls and rolled it up myself. (If) When ripping the film of there were a visible spark. Maybe just the ripping apart operation is enough to displace enough charge... (Thinking about ripping the skin of a cat, there will be things happening)
Offline krivx
  • Country: ie
« Reply #15 on: March 06, 2014, 04:03:12 pm »
Do you have the means to take any measurements while this is happening? Is the charge something you feasibly see on an electrometer? If you think significant energy is dissipated then it would follow that it is significant enough to measure...
What's the epoxy you are using? I have found that filled epoxies (usually marketed for low thermal expansion) are more conductive, you may be able to swap out the epoxy for something that does not allow charge to build up but also doesn't short out your board.
Not a physicist, but an EE working in Physics...
e: I would guess that your release agent forms a hydrophobic layer on the mould, I think this would just act as another dielectric layer. Hard to say without knowing what's used.
« Last Edit: March 06, 2014, 04:09:23 pm by krivx »
Offline Kremmen
« Reply #16 on: March 06, 2014, 04:08:57 pm »
That particular phenomenon is not a spark, instead it is triboluminescence, i.e. light induced by breakage of chemical bonds. Ordinary Scotch tape diplays this behavior. I have also processed my own films and this was an often seen thing.
Nothing sings like a kilovolt.
Dr W. Bishop
Offline krivx
  • Country: ie
« Reply #17 on: March 06, 2014, 04:10:12 pm »
« Reply #18 on: March 06, 2014, 06:08:07 pm »
Unfortunately it's at the subcontractor's place. It would be easy enough to verify - pull it from the mould and touch the ground of the flying lead to the mould - I suspect you'd get an audible spark.
However no spark wouldn't be conclusive as it could be that the occasional nature of damage is down to either unfortunate discharge or only occasional charge - it would probably need at least some charge to start with.
Obcioulsy I've now told them to connect the ground lead to the mould when releasing.
Offline G7PSK
  • It is hot until proved not.
« Reply #19 on: March 06, 2014, 06:20:58 pm »
Epoxy cures by an ionic exchange so there must be voltages set up within the epoxy as it cures.
Offline calexanian
    • Alex-Tronix
« Reply #20 on: March 06, 2014, 11:53:55 pm »
In my experience with potting products you are describing stress cracking. You may want to look into a softer encapsulant. there are specifically designed epoxy and polyurethane blends for electronics potting that give a little to allow the solder joints to remain intact. This situation is compounded if you have gold plated pads as well. We use a product from Aero Marine. Dow and loctite (Henkel) have a wide range of products that work quite well, some are even what I would describe as rubbery in texture for strain relief of your exiting wires. They also have a humiseal property for removing residual moisture from the components. In 25 years of using epoxy potting in sensitive electronics I am unaware of ever loosing a device to ESD from the potting process.
Charles Alexanian
Alex-Tronix Control Systems
Offline ConKbot
« Reply #21 on: March 07, 2014, 12:08:08 pm »
Ahh, the separation of an intimate bond between part and mold. Definitely a good chance for static to build up.  I remember getting 1-2" sparks off a table on hard rubber casters when I was pulling the vacuum bag off of it. The bag had been holding down a part to a form for a few hours in a 300*F oven.  take up the corners of each vacuum bag, then pull off one, then a second, carefully not getting too close to the table, and it had a nice charge built up on it.   And letting a coworker be the one to take the shock.   >:D
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #22 on: March 07, 2014, 12:16:28 pm »
I'm pretty sure one of the biggest advantages of epoxy is the fact that it does not shrink. This is the reason why epoxy is used for example high precision NC machine polymer concrete bases, the base does not change shape when it cures. There might be some differences between different epoxies though so I cannot be 100% sure this applies to all epoxies.
I think polyester based resin does shrink though.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Offline uwezi
    • GreenPhotons
« Reply #23 on: March 07, 2014, 12:42:20 pm »
My betting would also be mechanical stress rather than an electrostatic cause.
We used to do some experiments, trying to encapsulate solar cells in clear epoxy between two sheets of 2mm thick glass. The glass would crack from the while the epoxy is hardening!  This is probably not "shrinkage" even though epoxy does shrink while curing, but rather thermal expansion and contraction during the curing: the epoxy solidifies while it is hottest and then cools down again - shrinking.
http://gertrude-old.case.edu/276/materials/polymerencyclopedia/epoxy%20resins%20(overview).pdf
http://www.dtic.mil/dtic/tr/fulltext/u2/753943.pdf
http://www.expresspolymlett.com/letolt.php?file=EPL-0000181&mi=c
If it was an electrostatic problem, then I would not expect the failure to be located at the ends, but rather in the middle - and grounding the leads while curing the epoxy should solve the problem.
I also exclude the heat generated during the curing - that should also not concentrate on the ends.
But: when one short side attaches slightly better to the mould, then the stress from expansion/shrinkage would be largest at the other short end. It would not take much stress to rip off a narrow pitch SMD component from its pads. Have a look through the epoxy with a magnifying lens.
Offline IanJ
  • Country: scotland
  • Full time EE & Youtuber
    • IanJohnston.com
« Reply #24 on: March 07, 2014, 12:52:34 pm »
Back in the 80's/90's I used to do a lot of potting......can't remember the brand but it was 2-part black stuff that set hard with a glass like look to it.
3 pcb's stacked 7mm apart with soldered links between them. Mix of 74 & 4000 cmos.
It used to heat up quit considerably whilst curing and from time to time we end up with a faulty unit. We always put it down to mechanical stress. The faults varied.
Ian.
« Last Edit: March 07, 2014, 12:54:42 pm by IanJ »
Ian Johnston - Original designer of the PDVS2mini || Author of the free WinGPIB app.
Website - www.ianjohnston.com
YT Channel (electronics repairs & projects): www.youtube.com/user/IanScottJohnston, Twitter (X): https://twitter.com/IanSJohnston
