Author Topic: EUREKA !! LED tester with zero cost ..  (Read 3216 times)
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« on: May 02, 2010, 08:23:54 pm »
Everything started when I took my old RS diode- transistor  tester  apart for  cleaning , actually total wash and replaced the 9V battery too ...
As soon it become active again... I took an LED at hand, to test the functionality , the LED under test started flashing , no matter the polarity ..
This gave me the idea that the LED could possibly light on , also with the on board transistor tester ,
on my DMM ...  and it did   :D  , the voltage output are about 3V , so yes it can work out..
Check out the pictures ... emitter and collector.
