Author Topic: Cutting EL Panel  (Read 1187 times)
Offline don.rTopic starter
Cutting EL Panel
« on: November 09, 2019, 08:18:34 pm »
I purchased a small EL panel and was wondering is there are any recommendations on the best way to crop it to size. Its both a little tall and long for my application. Obviously I need to center the cropping on the pins. Anything else I need to worry about?
Offline Gyro
Re: Cutting EL Panel
« Reply #1 on: November 09, 2019, 08:33:45 pm »
At a guess... Atmospheric moisture ingress and possible delamination, causing degradation of the phosphor around the edge. Also the possibility of creating localised shorts between the upper and lower conductors.
I don't know for sure but I think they are edge sealed.
Best Regards, Chris
The following users thanked this post: don.r
« Reply #2 on: November 09, 2019, 08:44:48 pm »
I could mitigate the environmental effects by sealing the cuts in Scotch tape.
Offline m3vuv
« Reply #3 on: November 09, 2019, 08:56:28 pm »
The following users thanked this post: don.r, Gyro
« Reply #4 on: November 11, 2019, 10:16:29 pm »
I temporarily attached the new panel to the device and the light output is still very low. I measured the voltage from the driver and its only 16VAC rather than the 75VAC it should be. Looks like its the driver (a self-contained piece of unobtainium) rather than the panel. I'll hack in a modern driver and see if it works.
Offline Zero999
  • 0999
« Reply #5 on: November 11, 2019, 10:47:04 pm »
Yes, that doesn't sound good. The driver is probably fairly simple, quite likely a Royer converter.
I'm not sure that will work, since moisture will still get in. I think a clear lacquer will be better
« Reply #6 on: November 11, 2019, 10:52:06 pm »
I could open it up via a dremel and have a look but a new driver is less than $2 so...
Hopefully I won't need to go there right now but I'll keep that in mind for next time.
« Reply #7 on: January 17, 2020, 09:44:53 pm »
Finally got around to completing this after all the holiday business was taken care of. Got a $2 USB EL driver from Aliexpress and it works just fine in the Keithley. Will save the EL panel for future use.
