Sorry, not sure this subforum is a better fit than the others..
My cheapish 1,5 rpm mirror ball motor is too fast, I want it to turn slower.
It appears to be a geared AC motor (see e.g. bigclivedotcom's video on YouTube).
Dimming doesn't work well with synchronous motors.
Changing gears is probably too involved.
Using a variable frequency drive is too expensive (though there appear to be cheap VFDs for around 50USD) and may not work well or safely with this kind of motor and low frequency.
Are there cheaper BLDC options for a very slow direct drive (Odrive etc.)? Essentially that's also a VFD with separate supply.
Probably the simplest would be a stepper or geared DC motor?
Probably stepper and belt drive would be less noisy.
In addition, the bearing needs to be Fail-Safe so the whole thing can't fall down on anyone. Not sure what the actual requirements are and how the commercial ones implement that, but they are usually rated for mass and have a secondary safety hook.
I'm thinking that if something breaks, it shouldn't be possible to just drop out of the contraption. So maybe something like a T-shaped shaft (bolt with washer) that can't fall out of the housing even if the bearing etc. disintegrates). And if that should fail, the backup comes into play.
Does that make sense? Just here to bounce off these ideas and get some feedback 😁
