Hello,
I'm looking for help with what TR5 and TR6 are doing. I'm not quite sure as what they do ?? The Problem is TR5 BF 487 has gone Obsolete and we can no longer get.
I tried a MPSA44 but it does not work like the BF487. When you use the MPSA44 , R41 Gets Supper Dupper HOT(Technical Term) SMPS works but TR5 HOT
the BF487 had a gain of Aprox 50 ish , the MPSA gain of 1
Input voltage is 90 - 260 vac , outputs: 5v and 12v
Thanks for any help
