I have a similar action ongoing, I'm planning to reuse the chassis and panel of a broken Philips LCD TV. Mine however uses a LG panel instead.
According to what I know the cheap LCD controllers you can get require an LVDS extender, not only for the different LVDS connectors (51+31 Pins) but also for the 100/120 Hz conversion.
Still on my desk and awaiting some further work I have an HDVX9-AS V4.2 LCD Controller combined with an PL.MS6M30K.1 converter. You can find them a lot on the usual Chinese seller sites and on ebay.
Mine was pre-configured for the LG panel but there is also an option for the samsung panels. If I got it right it only requires some resistors to be moved for the change.
Have a further look around and maybe start searching from the panel model number, smaller set for notebook panels are known and partly well documented.
My project is not done so I cannot provide you more information.
Cheers, Geronimo
