Author Topic: Inverted Alligator Clips?  (Read 8445 times)
Offline hal9001Topic starter
« on: April 14, 2024, 09:58:24 pm »
Are there test clips that work opposite direction of alligator clips? I want the clips to compress whilst pressed and open whilst let go. I want to measure inside different diameter holes using spring force to hold the clip.
Cheers
Offline donlisms
Re: Inverted Alligator Clips?
« Reply #1 on: April 15, 2024, 08:02:12 pm »
I think crocodile clips are sprung outward, with a sort of crossover action.  You would have to experiment with different modifications to remove the parts you don't want, and shape the jaws.  This only works if you have a file and pliers and don't mind getting your hands a little dirty!  :-)
Online jpanhalt
« Reply #2 on: April 15, 2024, 08:36:00 pm »
Why not use a spring loaded, inexpensive hole gauge (attachment)?  They come in quite small sizes.  The ends are domed so they self-center a little, but not as well as much more expensive 3-tab hole gauges.
Offline CaptDon
  • Country: is
« Reply #3 on: April 16, 2024, 01:38:18 am »
How on earth does an inverted alligator clip help you measure an I.D.? One would think you would use standard methods like inside calipers or any standard accurate measuring means.
Offline donlisms
« Reply #4 on: April 16, 2024, 02:12:15 am »
I don't think OP wants to measure the ID; this is an electronics forum, and I think he wants to make electrical measurements.  Inside holes.  Of various sizes.
Thus... something vaguely like an alligator clip that works backwards; tension outward, gripping the inner wall.
The following users thanked this post: thm_w, hal9001
Offline PCB.Wiz
« Reply #5 on: April 16, 2024, 02:48:50 am »
That's non standard, but you could modify existing clips ?
You could reverse the spring, or you could solder on extended fingers, bent & crossed over so that when they are in the hole, they prevent the clip fully closing
There are also barrel connectors and terminals, that are designed to go into holes, that might work too.
What sized holes do you want to probe ?
The following users thanked this post: hal9001
« Reply #6 on: April 16, 2024, 07:14:50 am »
Thats precisely it!
Inner diameter can be from 5mm to 10mm. They are hand drilled holes where the outside is coated with insulation so I have to take measurements inside of the holes.
It neednt be alligator clips, it was the first thing I thought of.
Offline PCB.Wiz
« Reply #7 on: April 16, 2024, 07:38:15 am »
They are sprung loaded and common, so not a bad place to start.
Aliexpress have banana/bullet plugs up to 2.5-8mm
For larger holes you could use the rear end of a bare alligator clip, extended to fit the hole.
Offline NiHaoMike
    • Facebook Page
« Reply #8 on: April 16, 2024, 12:44:22 pm »
Would be easy to make one by bending a strip of springy metal into a U shape.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Offline MLXXXp
« Reply #9 on: April 16, 2024, 10:10:06 pm »
How about cutting off the head and point of a safety pin, bending it to shape if necessary, and soldering a wire to it?
Offline TimFox
« Reply #10 on: April 16, 2024, 10:57:33 pm »
Real crocodile clips are sprung the same way as real alligator clips.
The difference is that the upper jaw of the crocodile clip goes within the edges of the lower jaw when closed.
See  https://www.muellerelectric.com/products/bu-85c
Since they were introduced by Mueller many years ago, other vendors have treated alligator and crocodile as synonyms, another incidence of obscuring useful differences between similar objects.
Offline Smokey
  • Not An Expert
« Reply #11 on: April 16, 2024, 10:58:52 pm »
What size holes are you talking about here?
Offline notsob
« Reply #12 on: April 17, 2024, 12:12:56 am »
If you only need to check for specific size compliance, why not use some gauge pins for a go / no go test
Offline donlisms
« Reply #13 on: April 17, 2024, 03:15:17 am »
Hm.  I was thinking of something more like the Mueller BU-45, which I guess is not "real"!  :-)
Offline TimFox
« Reply #14 on: April 17, 2024, 03:20:40 am »
The BU-45 is neither an alligator nor crocodile clip.
https://www.muellerelectric.com/products/bu-45
Offline donlisms
« Reply #15 on: April 18, 2024, 07:16:53 pm »
Regardless, those are what I was thinking of.  I've heard them called crocodile clips since most folks here were born!  Cut me a little slack, eh?  Just trying to help.
Offline TimFox
« Reply #16 on: April 18, 2024, 07:44:49 pm »
In my youth, which predates most of the members here, they were often called “battery clips”.
My pet peeve is treating “alligator clip” and “crocodile clip” as synonyms, when the Mueller catalog shows the clear difference.
Citing the Mueller catalog page is my way of helping.
Mueller invented alligator and crocodile clips in 1908, which is before my time.
« Last Edit: April 18, 2024, 07:47:43 pm by TimFox »
Offline mzzj
« Reply #17 on: April 18, 2024, 08:27:13 pm »
I can imagine these would be really handy in some situations but it seems like non-existent product or it goes with so exotic name that it doesn't show up with regular google-fu.
Some alligator clamps look like they would be reasonably easy to modify with dremel, soldering iron and bunch of metal pieces but I get that ready-made product would be nice if you need more than 2.
Offline rdl
« Reply #18 on: April 19, 2024, 02:06:52 am »
Offline Dundarave
« Reply #19 on: April 19, 2024, 05:34:54 am »
If you’re just looking for something quick and dirty, the steel wire handles of steel, black, paper binder clips can be removed from the spring clamp itself, and they spring “outward”, as it were, and have a convenient loop to fasten a probe.
They come in sizes from 3 inches down to 1/2”, and are available at pretty much any stationery store.
You could remove the handle from the clip, compress the ends, put it down the hole, and the legs will bear against the side of the hole.  Cheap and quick.
Offline radar_macgyver
« Reply #20 on: April 19, 2024, 01:11:07 pm »
For small diameter holes, you could use a Keystone test point or similar:
https://www.keyelco.com/category.cfm/Test-Points-Tips-Probes-Clips/Test-Points-color-keyed-Thru-Hole-Mount/id/521
Looking at how the 'without base' ones are made, just bend a piece of phosphor bronze wire into a U shape and you're done.
