Author Topic: Sensitive AC voltage detector  (Read 2754 times)
Offline skylerTopic starter
« on: February 02, 2016, 12:57:05 pm »
I am launching a high altitude balloon in a few weeks with the High School club I started, and we are rushing design after design to get things working.
The experiment we are launching on the balloon is a Field Mill. We based the design off this link .
After finally getting the field mill to work, we need to somehow feed the AC voltage into the 0-3.3 volt datalogger. I am fairly inexperienced, but I saw that I might need a preceision rectifier, a peak detector, and maybe an amplifier if the signal is too low.
Could someone help with a circuit, we don't have much time to research what is needed, and what I order today has to work.
Offline Kleinstein
Re: Sensitive AC voltage detector
« Reply #1 on: February 02, 2016, 02:24:48 pm »
The amplifier of choice is usually a FET based OP. At low voltage a CMOS OP like MCP602.
To get good separation of the AC signal from the field mill and noise a kind of Lock-In scheme is helpful instead of simple rectification or peak detection. This can be done with the help of CMOS switches to make an amplifier that is switchable as +-1. However this also needs a reference clock, from an extra detector (e.g. CNY70).
Depending on the datalogger / µC one could also feed the AC voltage to the ADC and do the amplitude determination in software.
Offline LaserSteve
« Reply #2 on: February 02, 2016, 03:12:25 pm »
Maybe not sensitive enough for a atmospheric mission:
http://freespace.virgin.net/paul.zimmermann/Electronic/ep3.htm#My
One with synchronous (lock-in) detection:
http://www.qsl.net/dh1stf/aufbauae/images/schaltung.gif
Steve
"What the devil kind of Engineer are thou, that canst not slay a hedgehog with your naked arse?"
I am an unsullied member of the "Watched"
Offline CaveMannDave
  • Upside the Downside
« Reply #3 on: February 02, 2016, 04:04:38 pm »
Hi:
My audio died, but watching the Pretty Moving Pictures, I infer this is some kind of electrostatic Field detector, measuring tiny changes in intensity by chopping techniques.
Excellent Idea, IMHO.
I recently ran across a reference to this method, and searched it out (that is my way of learning, I run-to-ground any New concept, and devour it whole.)  The Mongoose clan, as related by Riki-Tiki-Tavi{sp?}, (their spokes-critter in the R. Kipling Jungle Book stories) had a motto or Mantra, that if you wanted to Know a Thing, go run-and-find-out...            Sorry for that digression...
Anyhoo, it boils down to, you can recover minuscule signals from Overwhelming background interference through using chopping methods and synchronised demodulators: Also known as Lock-in Amplifiers...                BINGO!     Just fits your need.
They can cost tens of thousands for Lab-Grade units, but an Analog Devices, or other analog multiplier IC, a clock recovery PLL, (I'm assuming single channel, Manchester-encoded {Way old School} or otherwise data w/clocking transmission method) to recover synch, some active filter stages, and Very Little Else will deliver a nice, clean DC output of the signal desired.     The S/N can scare you.
Just get a GOOD synch signal from the remote sensor, and use daWebz to find the other trivia, ask for detail help, if needed, and breadboard away!
It is a really simple concept, with Dozens of ways to get there, and YOU get to choose what fits your needs/personal-biases/wallet/whims or whatever.
There are many ways to Skin that Cat! ;D
ETA:  Look into Log Amps, to compress wide data ranges into a low-res DAQ.
Also consider Voltage-to-Frequency conversion for fidelity of transmission and logging.
Cheers,
Dave
« Last Edit: February 02, 2016, 04:24:43 pm by CaveMannDave »
Some say that I'm a wise man. Some think that I'm a fool.   It doesn't matter either way,  I'll be a wise man's fool.  For the lesson lies in learning, And by teaching, I'll be taught,  There's nothing hidden anywhere, It's all there to be sought...
(Procol Harum, "In Held Twas In I")
