G'day Ricko,
I've been working with cars and engines as a hobby since the 70's. I've learned a few things about automotive ignition systems over the years. By the way, since you're in the UK, you might appreciate that I'm helping a neighbor campaign his 1960 Austin Healey Sprite at the local vintage races. He was doing well until, in an unsupervised moment, tried to run it on diesel. (sigh).
Indeed, resistance wire or spark plugs with integral resistors are used to suppress RFI. They do it by limiting current risetimes. Consider the secondary circuit. The ignition coil generates a voltage that charges up the capacitance of the coil and the ignition wire until the voltage is great enough to cause the spark plug gap to break down and conduct, discharging the capacitances and the ignition coil inductance. If the breakdown voltage is 20 KV, the wire and coil are 4000 ohms and the spark is 1000 ohms, the peak current could be 5 A. The current risetime would be short, on the order of a few microseconds. Worse, the ignition wire forms a loop with the engine block and the car's structure that makes a dandy transmitting antenna. Resistor wires slow down the rate of rise of current and the peak current. If the wire's resistance is 20 K, the current risetime extends to 10 microseconds and the peak current to under one amp. This reduces the amplitude of the transmitted RFI and shifts the spectrum downward in frequency.
As Zero999 says, there is an interplay between the resistances, inductances and capacitances. The actual equivalent circuit is quite complicated and requires differential equations or a circuit simulator to solve accurately. Your simplified circuit does not show the ignition coil secondary, an important part. If you could tell us more about the application, what the requirements are and if you have some parts already chosen. ie., the ignition coil. One other consideration is that if the spark plug fails to spark or if the ignition lead falls off, the stored energy will have no place to go and may stress the primary components.
I repaired a CDI unit once, but I'm not sure of the waveforms across the coil primary and the switch. Looking at prior art, I see that CDI systems arrange the capacitor, switch and ignition coil differently, see attached figure. I'm not sure why it was arranged this way but I believe it allowed for a simple switch that could bypass the CDI if something went wrong, and use the original points and condensor. It may be possible to rearrange the circuit closer to yours. The circuit shows an SCR for the switch. I haven't seen any other type of device used here, but it's possible. SCRs have a handy feature in that they will self commutate, ie., once triggered, they will stay conducting until their anode current drops to zero. SCRs don't generally conduct in the reverse direction so if that's important, it rules out using a MOSFET without some additional diodes to isolate the body diode. Some IGBTs, but not all can operate with high reversed C - E voltages.
Gotta run,
Cheers,
