One thing I should perhaps mention is that lifters require asymmetrical electrodes.
In pretty much every lifter guide, paper, website, design etc you learn that the better the asymmetry, the better it lifts. Fair enough, they have good experimental evidence to show this consistently is an important factor in their designs. I doubt they could make a lifter that lifts with symmetric electrodes. Better ionisation and asymmetrical positioning of initial ions to give an assymetrically applied force are two reasons why you'd need asymmetrical electrodes. I'm saying everyone is using a design that's easy to make, not one that best utilises the physics. I stand firm, symmetrical electrodes can work.
I tried swapping the polarity. The direction of thrust remains the same. Efficiency was better with the small (wire) electrode +ve irrc
Hehe, this was fun to figure out. Same direction of force with reverse polarity is due to positive vs negative ion acceleration. Figuring out why it gives more thrust in one polarity took me a bit longer to understand, I won't spoil the puzzle. Do you have numbers on the the difference? (force, volts, current, electrode shape and separation for each polarity)
Was the horizontal axis of your graph supposed to be labeled in kV instead of V?
It's V, if you read the title, this is the total power for lifting a "mass" (it's a pretty heavy mass). It's the general shape of the curve that's important, not the vertical scale which will vary with lifters, typically in W rather than MW.
At such "low potentials" as shown you will get no ionization at all! The potential required is closer to 25,000 V.
Exactly! This is the best forum ever, so many thinkers.
Quoting myself:
The low part of the curve (high efficiency of Force to Power consumption) is inaccessible with current lifter designs.
I'm not suggesting the engineering is simple to get around this problem, but I've got ideas. I'd like to first verify experimentally that what seems impossible is actually doable. I'd like some help from some electricity savy people on this forum with an experimental setup to make some basic measurements and test physical models, i asked before but I'll try again with slightly better diagrams.
[see attachment]
