The vapor pressure is, of course, not the whole story, as it only describes an equilibrium fraction of the gaseous phase of a substance in air. Even the "very low" 2.4 mbar of Hg is far above the long-term exposure limits if that was evenly mixed in a breathable airstream: precisely the reason that experiments with mercury require fume hoods. I understood the OP question to be about all routes of contamination, including solid dusts, and at the surface of a corona electrode, which is far from room temperature.
My suggestion would be to use stainless steel needles, since they are good at resisting corrosion, and corrosion products are mechanically weak and would be the most likely form to enter the air as dust during the ultrasonic and temperature shock of corona discharge. Stainless steel can only be soldered using highly active fluxes such as phosphoric acid. The solder joints themselves will be far from the arc points and experience negligible deterioration or fragmentation into the air. Therefore, lead in the solder will not be a problem, however, lead-free solders with silver are mechanically stronger and would be preferred if they can be used with low failure rates. You can use high-dielectric varnishes or paints to seal the circuit beneath the needles to prevent undesired corona in that area.
Ozone is a very widely-used and non-toxic method for disinfection and odor neutralization. Its corrosive properties are what kills microbes, and likewise irritates the mucus membranes and the lung alveoli. It quickly dissipates after use and there is no residue with articles treated in this way.
