Author Topic: IR communication protocol/design for low latency/fast response - ideas?  (Read 5350 times)
Offline pwlps
IRDA association did not pick phase modulation but PPM instead for a good reason.
No, you still don't get it. I give up.
Offline grifftech
    • youtube channel
visable light, 1 wavelength per pair
Offline ogden
  • Country: lv
No. *You** don't get it - that it is pointless to double-modulate signal.
Offline pwlps
I get it perfectly. It might be pointless for a single channel but the OP precised it has to handle independent communication channels. Buriedcode suggested using different carriers and I tried to develop the idea.
Here is the (basic) point you don't get yet. The direct OOK modulation such as used in IrDA (with various coding schemes, NRZ etc.) has a broad spectrum(fundamental defined by the bitrate+harmonics +possibly some subharmonics depending on the coding scheme) and it is not possible to define isolated channels by just using different modulation frequencies. The purpose of double modulation (carrier) is merely to shift the entire spectrum to some high frequency band, then choosing a large enough spacing between carriers you can have completely isolated channels.  I hope it was clear this time.
« Last Edit: May 24, 2019, 08:31:34 am by pwlps »
Offline ogden
  • Country: lv
Please be so kind and show quote where he said so.
You did not develop idea of different carriers. Different carriers in optical communications means different wavelengths. https://en.wikipedia.org/wiki/Wavelength-division_multiplexing
LOL, no. You suggest to use same carrier frequency - same wavelength of light, same type of IR LED to transmit multiple channels?  :-//
Offline Marco
Wavelength division multiplexing is used because the individual bandwidths of the signals are already pushing technology limitations. Modulating a laser with a modulated 1 THz carrier to get 100 10 GHz bands is not technologically possible, with a MHz carrier and 100 10 kHz bands it is.
Now whether frequency division multiplexing is a better way to share the spectrum than time division here is debatable.
« Last Edit: May 24, 2019, 12:58:41 pm by Marco »
Offline pwlps
Of course it is possible to use the same wavelength of light and same type of IR LED to transmit multiple channels. That's what it all was about.
Offline ogden
  • Country: lv
Of course time division of pulse-modulated signal is most effective way for said application - because available bandwidth is more than needed.
Well, then explain your phase modulation principles of IR LED light which does not allow phase (of the light) modulation. You BTW did not provide quote of OP asking  independent communication channels.
Offline Buriedcode
Lads, the OP hasn't returned, can we at least keep on topic.
Offline ogden
  • Country: lv
Are you moderator? Which part of our discussion you find off-topic? We *are* talking about subject "IR communication protocol/design". You think we are not?
Offline pwlps
Of course, but here we were not talking about how to optimize a standard for best spectral efficiency, the question was rather how to make a simple but robust system with a few channels, focusing on the ease and robustness of the actual implementation. TDMA will work with simpler electronics but will need a more robust software protocol (collision detection etc.), FDMA needs more analog stages but eliminates many problems too. Consider such an annex problem like the AGC training: in FDMA this is handled by the analog stage IC, but in a direct carrierless coding you don't have it and I don't even know how it is achieved, do we need to append long preambles ?
« Last Edit: May 24, 2019, 06:25:15 pm by pwlps »
Offline pwlps
I don't have time to give a course on modulation now but note that there is nothing new here. Carrier modulation is used in IR remote control standards like Sony SIRC or Philips RC-5 : https://en.wikipedia.org/wiki/RC-5. In RC-5 "the command data is a Manchester coded bitstream modulating a 36 kHz carrier". As you see the carrier has nothing to do with the optical frequency. NB. In the standards I'm citing only amplitude modulation is used but there is no reason a phase modulation (BPSK, QPSK etc.) could not be used as well. Please try to understand all this before your next post.
« Last Edit: May 24, 2019, 06:52:46 pm by pwlps »
Offline pwlps
As long as the discussion is entertaining who cares about the OP  :D
Offline ogden
  • Country: lv
Don't even try please.
When you properly tell what actually is carrier - then sure. Look... I do not deny possibility of signal double-modulation, nor possibility to transmit QPSK-modulated baseband using amplitude modulation of IR light. What you propose is indeed possible to build, but it is pointless overengineering. It is already said multiple times here - pointless.
IR remotes do not use amplitude modulation but OOK (on/off keying), even for "modulation of the carrier". BTW IR receivers have pathetic selectivity - if you point interfering (transmitting) 56KHz remote to 36KHz receiver, it can't decode 36KHz transmission aimed at it. That "carrier modulation" for TV IR remotes does not create parallel transmisison channels, it is just smart balance between design complexity and protection against false triggering from ambient IR noise and other kind of TV IR remotes.
« Last Edit: May 25, 2019, 07:56:42 am by ogden »
