if you hook two steppers back to back (without power) you can turn one with the other based on the EMF generated by the one you turn. Not much torque at all but it is interesting.
Look up quadrature encoding. This is how you decode encoders with a microprocessor. The two pulses are offset so that dependng on how the encoder turns, one or the other pulse will lead or lag the other and based on that, you get the direction and step.
So turning one way you'll get a pulse train of ABABABAB as to which leads the other; The other way, BABABABABA. Remember, that the transition from A to B and from B to A is which leads. So you really have A, and while A, then B; The other way, B and while B, then A. I think they call it quadrature because you can have four states: not A & not b; A; B; A & B. Most microprocessor libraries have quadrature encoder libraries or code.
Jerry
