Author Topic: Voltage regulators - die pictures  (Read 59380 times)
Online magic
Re: Voltage regulators - die pictures
« Reply #175 on: November 15, 2024, 10:11:54 pm »
Maybe slightly better ;)
But WTF is this circuit here? I gather the first MOSFET pair is a P-ch current mirror (gate shorted to "southern" drain) and the next is an N-ch differential pair, and they drive the output FET directly. Pretty obvious so far.
The rest must be the voltage reference, and what exactly happens here? Looks like the current source from the simplified schematic is a series pair of N-MOS with gates shorted to sources (or floating?), and the "resistor" is a diode connected(?) N-MOS. And this is supposed to produce a constant voltage? :-//
« Last Edit: November 15, 2024, 10:17:31 pm by magic »
Offline NoopyTopic starter
    • Richis-Lab
« Reply #176 on: November 16, 2024, 04:08:20 am »
The circuit is really extremly simple.
It seems like it is just a very simple differential amplifier looking at something like a zener reference with a resistor "current source".
If you balance everything as good as possible that is perhaps stable enough.
