Do you get such circuits in a all inclusive IC?
Yes!
But I admit this is a difficult one to find if you didn't have the correct keyword ("Window comparator")
http://cds.linear.com/docs/en/datasheet/1042fa.pdf
"Two high impedance voltage inputs, CENTER and WIDTH/2, define the middle and width of the comparison window"
I had to divert my attention to other work so that's why there is a 2 week delay in my reply.
I am fully aware of windows comparators. I guess my lack of understanding my won problem made me express my problem in a bit inaccurate and incomplete.
Well after reading the data sheet in "Emmanuel Faure" reply I found this phrase.
An important feature of the LTC1042 is the non-interaction
of the inputs. This means the center and width of the
window can be changed without one affecting the other.
Also note that the width of the window is set by a ground
referred signal WlDTH/2).
This is exactly what I was looking for. I want my voltage window width to be fixed and independent of the window center as I change it. I will only change the center.
Thanks Emmanuel
How does this forum work? Is there a place to mark this thread as solved? Maybe give you some points for not posting a reply that just push up your post counter?
