Author Topic: Omega Z33 quartz watch  (Read 4975 times)
Offline WytnuclsTopic starter
« on: November 21, 2013, 04:53:53 am »
Omega released an expensive pilot quartz watch last year with normal hands, but also an LCD display, which actually looks like a LED display. I wonder how this is achieved.
With a red LED backlight probably, but I'm not sure how the reverse video effect is done with the LCD. Any thoughts?
« Last Edit: November 21, 2013, 05:06:21 am by Wytnucls »
Re: Omega Z1 quartz watch
« Reply #1 on: November 21, 2013, 05:07:16 am »
Simple to use a red filter on the LCD reflector and a phosphor coat on there to generate extra red light from the incoming blue or UV light to add extra red light to the display. Do not think a backlight will be used as then battery life will take a dramatic drop.
Re: Omega Z33 quartz watch
« Reply #2 on: November 21, 2013, 06:53:30 am »
Your explanation is possible, but the display needs to switched on with the push of a button, so red backlight is more probable, under a negative display. Is a negative display more power hungry than a positive one?
In addition to the temperature-controlled crystal, power consumption could be quite high.
« Last Edit: November 21, 2013, 07:01:54 am by Wytnucls »
« Reply #3 on: November 21, 2013, 07:03:15 am »
Definitely comes with a red auto-adjust backlight.
Found this:
Offline Magicmushroom666
« Reply #4 on: November 21, 2013, 08:37:32 am »
You can usually change LCDs from normal to inverse operation (such as here) by just rotating the front polariser by 90 Degrees I think, Have done this in the past before with a standard car stereo LCD.
Offline Balaur
« Reply #5 on: November 21, 2013, 09:00:11 am »
Or just reverse the polariser foil (turn it on the other side)
« Reply #6 on: November 21, 2013, 09:01:00 am »
Thanks, I think you're right. Not sure how it works yet, but I found this wikipedia picture:
So there shouldn't be any power hit.
The LCD screen is transflective, meaning that during daytime, ambient light is reflected back and at night, it is LED illuminated through a red filter.
« Reply #7 on: November 21, 2013, 11:08:04 am »
Well, it has, but the backlight is energy hungry, so can't be left on all the time, hence the button press. Some generator powered by wrist movement might work one day.
« Last Edit: November 21, 2013, 11:10:18 am by Wytnucls »
Offline dannyf
« Reply #8 on: November 21, 2013, 12:04:34 pm »
Positive lcd + red filters / background.
