http://www.ti.com/lit/an/sdya009c/sdya009c.pdfif a high level is required, it should be connected with a voltage source corresponding with a
high level. In general, this is the positive supply voltage VCC. Figure 10 shows how, in the previously mentioned cases, a fixed
potential should be connected to unused inputs. Note that a high level should be applied to the unused inputs of an AND
(NAND) function and a low level to unused inputs of an OR (NOR) function.
Devices with multiple-emitter inputs (SN74 and SN74S series) are exceptions. Since no voltage greater than 5.5 V should be
applied to the inputs (because if exceeded, the base-emitter junction at the inputs breaks down), the inputs of these devices must
be connected to the supply voltage VCC via series resistor RS (see Figure 11). This resistor should be dimensioned such that
the current flowing into the gate or gates, which results from overvoltage, does not exceed 1 mA. But, because the high-level
input current of the circuits connected to the gate flows through this resistor, the resistor should be dimensioned so that the
voltage drop across it still allows the required high level. Equations 1 and 2 are for dimension
