SMD Microphone - ADMP421 -
http://www.analog.com/static/imported-files/data_sheets/ADMP421.pdfThis is being used on a small 2-layer PCB (not hand-made). I'm using decent (fresh) leaded solder paste, and a hot air station to reflow it (the same WEP/ATTEN 858D that Dave played with a while back). Simple Weller iron for touch-ups. I don't have a solder stencil, I've just been relying on dabbing the paste on the pads carefully and relying on the surface tension and soldermask to tidy it up during reflow.
This is what the footprint looks like (although the silkscreen layer didn't get printed so placement isn't easy at all without a p&p robot doing it
I didn't have any trouble with the rest of the components on this board - 603 caps and resistors, and no problems with resistor arrays or the SOT transistors, or the RTC IC. All of those were fairly painless and I only had a couple solder bridges to repair on the arrays.
But this microphone is being a royal PITA. The solder seemed to wet and pull the device into place, but it failed testing afterwards. I ended up using the heat gun to pop it back off, and it looks like maybe the VDD and/or L/R pads didn't reflow. I don't trust the device to be undamaged at this point, so I'm ordering a replacement. They are $4 each though, so I don't want to keep chewing through them by failing the reflow again (and there is also the danger of board damage with these tiny pads). Lastly, there is the concern about solder flowing into the microphone port... the ring around the port must solder correctly, but without any flowing into the hole itself
Any tips for getting this thing soldered correctly?
I'm thinking of making a poor-man's solder stencil using a paper stencil (if I can manage the precision needed for that). But other than that, I'm not sure what other tricks I could pull.
I could also ditch this part altogether and replace it with an external condensor microphone circuit, which would also require some changes in the FPGA code that this board hooks up to... but I would rather get the original designed digital microphone part working if I can.
