Dear everybody,
I'm running in a hardware question regarding a power-meter project using a integrated high side current sensor.
I have decided to go for the MAX9611 which is a "plug and play" I2C device, and have completed the project which is running nicely. I have followed religiously the datasheet so that the A/D conversion is computed in software and displayed exactly as specified. I used a 10mOhms shunt resistor wired properly (2 fat traces for the current path, and 2 fine traces running from the resistor to the MAX9661). Prototype all mounted on a PCB.
1) When the input of the shunt are left floating, values measured for I and U (common mode voltage) are erratic. What would be the best way to clamp the shunt in order to get a steady 0 when left floating? I tried putting 1MOhms to ground on each terminals of the shunt, which fixes the readings for U, but not really for I.
2) When grounded, I do not get a true "0" output on the ADC. I could fix that using an offset in software though, if that is normal. I don't know yet if my readings compare well to a calibrated multimeter.
Any help would be appreciated
