Author Topic: Modulating 1Mbit data into FSK  (Read 492 times)
Offline hazukiTopic starter
« on: March 17, 2021, 09:22:35 pm »
Hi all. I have a strange application where I want to modulate a 1Mbit data stream into FSK or PSK to send over an optical link. The reason I want to do this is because the optical link has a minimum bandwidth of 20Mbit/s but a maximum bandwidth of 5Gbps. So I was thinking to modulate this 1Mbit data stream into a 100MHz or higher carrier. Any recommendations on how this can be done? I'm looking at frequency synthesizer ICs but they have state transition times on the order of 1us and I'd like something a little faster as to not introduce a large propagation delay to the 1Mbit/s signal.
Thanks
Online T3sl4co1l
    • Seven Transistor Labs
Re: Modulating 1Mbit data into FSK
« Reply #1 on: March 17, 2021, 09:39:44 pm »
How about Manchester encoding?  Cheap, a clock and a few gates will do the trick.  Wasteful, takes something like twice the bandwidth -- but it sounds like you have more than enough available so that won't be a problem.
Seven Transistor Labs, LLC
Offline langwadt
« Reply #2 on: March 17, 2021, 10:13:58 pm »
100MHz clock and an XOR and you have PSK?
