Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Motor/generator
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Motor/generator (Read 556 times)
tropes
Newbie
Country:
Motor/generator
on:
July 10, 2021, 10:34:16 pm »
I have a driven shaft turning a PMSG connected to a three phase rectifier creating a 24 volt DC output current.
http://lightswitchracing.com/55W.MOV
I also have a motor controller connected to the PMSG using 24 volt DC input, that turns the PMSG shaft at 350 rpm.
I have been disconnecting the rectifier and connecting the motor controller to switch from generator to motor.
Is there a way to switch the PMSG from a generator to a motor without disconnecting one and connecting the other?
Last Edit: July 14, 2021, 09:50:55 pm by tropes
Logged
NiHaoMike
Super Contributor
Country:
"Don't turn it on - Take it apart!"
Re: Motor/generator
Reply #1 on:
July 10, 2021, 11:14:05 pm »
You need a motor driver that supports regeneration.
Logged
tropes
Newbie
Country:
Re: Motor/generator
Reply #2 on:
July 10, 2021, 11:24:33 pm »
Thanks, and where would I find this motor driver that supports regeneration?
Logged
NiHaoMike
Super Contributor
Country:
Re: Motor/generator
Reply #3 on:
July 11, 2021, 01:47:49 am »
Check the documentation to see if there's a mention of it or something like "regenerative braking".
Logged
tropes
Newbie
Country:
Re: Motor/generator
Reply #4 on:
July 11, 2021, 01:50:38 am »
Thanks, I did and found info.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Motor/generator
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
