Hello,
Day to day I work on testing capacitive pressure sensors for our lab in the range of 5 - 200 pF. One application of our sensors is to measure pulse rate. We can do this by strapping a sensor to the wrist like a watch, though the wires still go off to a bench LCR meter. We can then find pulse rate by performing an FFT. What I'd like to do is make this field portable by having some capacitance sensing electronics in the casing of the "watch" to record to an SD card.
There are few issues with going about this that I need some advice on.
Firstly, the choice of capacitance sensing method. My idea at the moment is to have a micro generate a 1 Vpp 1 kHz sine wave from either a built-in or external DAC, buffer / amplifier if needed, current sense resistor, followed by our sensor. Then use an ADC over the resistor for current, over the capacitor for voltage, and use V = I/jwC to get the capacitance. If the series resistance needs to be accounted for I could instead measure the peaks and phase difference between the current and voltage and work backwards from impedance to capacitance. Is this a good way of going about it?
Secondly, I've not implemented a micro myself before. I've only programmed dev boards where everything has been plug and play. To fit everything into the size constraints (~ size of a watch) I think I would need to make my own but it's intimidating. Especially for connecting my own programmer (never used JTAG, and it looks large profile) or an external crystal. If there are any great tutorials I'd appreciate being directed to one.
Cheers,
Fraser
