Author Topic: Is there a voice controlled TV (universal) remote for handicapped people?  (Read 1902 times)
Online eliocor
    • rhodiatoce
« Last Edit: January 23, 2025, 10:22:21 am by eliocor »
The following users thanked this post: Greybeard
Offline Langdon
    • My website + My software
Re: Is there a voice controlled TV (universal) remote for handicapped people?
« Reply #26 on: January 23, 2025, 03:42:29 pm »
Simple is good.
Low-tech solutions are awesome!
I like the idea of just 5(3) buttons:
POWER
VOLUME UP/DOWN
CHANNEL UP/DOWN
The volume and channels are limited to what the user wants (only the channels the person likes can be selected)
If the user is hard of hearing, the volume should probably have only a couple available levels:
Earsplitting, less earsplitting, normal(to prevent those who are not hard of hearing from becoming so), and mute.
Voice recognition seems a bit overkill.
Most people eho are diabled and hard of hearing are not familiar with voice-activation.
Plus, there are a lot of problems with voice control.
Imagine this scenario:
What person says: "I turn on the TV every day and watch CP24."
What the remote hears: "Turn on the TV."
AI ain't as intelligent as people think.
Sometimes, it is really smart; other times, it is SO stupid!
My website used to be www.getpacman.gq
It is now www.langdonstaab.ca
"Low-tech solutions are beautiful"
Offline Langdon
« Reply #27 on: January 23, 2025, 03:44:25 pm »
Any speech recognition solution for German will be sub-par.
All the work goes into English (or possibly Chinese, etc.)
Offline coppice
« Reply #28 on: January 23, 2025, 05:17:41 pm »
It depends a lot on the nature of the language. 25 years ago almost all effort was on English and Mandarin. However, I found the best reliability to be with the Cantonese recognisers, which had only had a small effort put into them. I'm a native English speaker, and a second language rather poor Cantonese speaker with a terrible accent, and I had much better results with the Cantonese recognisers.
Offline GreybeardTopic starter
« Reply #30 on: January 23, 2025, 06:44:20 pm »
You can use a mic activation button that activates the system only while the button is pressed.
That button can also mute the TV.
« Last Edit: January 23, 2025, 06:46:40 pm by Greybeard »
« Reply #31 on: January 23, 2025, 06:49:20 pm »
What about self-learning systems?
Offline Fryguy
« Reply #32 on: January 23, 2025, 07:03:11 pm »
How about something entirely mechanical ?
One big button and an industrial grade joystick ( with mechanical switches ) wired to the original or a cheap universal remote control .
Button : on/off
Up/down : channel up/down
Left/right : volume up/down
Super easy to make . . .  :popcorn:
This is a real self-learning system - it knows what to do when it is fully assembled . . .  :-DD
« Last Edit: January 23, 2025, 07:57:36 pm by Fryguy »
Born error amplifier  >.<
Offline Psi
« Reply #33 on: January 23, 2025, 09:14:12 pm »
A camera with hand gestures detection would be interesting.
Basically you 'sign' the command you want.
It has the advantage of not being audio based so wont get confused with TV audio, doesn't need to mute it, and detection could be locked down to only see you signing when seated in a specific TV watching chair/sofa
« Last Edit: January 23, 2025, 09:16:16 pm by Psi »
« Reply #34 on: January 23, 2025, 10:13:26 pm »
Button : on/off
Interesting.
Also interesting.
Offline Langdon
« Reply #35 on: January 27, 2025, 08:15:37 pm »
Cool!
That's so strange!
Perhaps the phonemes in Cantonese are easily interpreted by a computer and cheapo mic.
Or maybe the people the machine learned from have the same accent and broken Cantonese as you do!
