Author Topic: BNC connector mounting  (Read 1937 times)
Offline VgkidTopic starter
« on: April 28, 2015, 04:23:50 am »
How would one mount a female BNC pannel mount connector, without making the D shaped holes. Could I just titen down the nut all the way.
Offline Richard Crowley
  • KJ7YLK
Re: BNC connector mounting
« Reply #1 on: April 28, 2015, 04:49:58 am »
Sure, people do it all the time. But you wouldn't have much protection against rotation.
Offline kjs
« Reply #2 on: April 28, 2015, 04:52:12 am »
the D-shape prevents that the socket is loosening over time (and it will otherwise). I usually drill the hole pretty tight and put a very small amount of Epoxy glue into the D as a makeshift solution when I don't have a way to get them done properly. A pain to get the jack out again but better than always re-tightening the nut and a spinning jack.
« Last Edit: April 28, 2015, 04:55:47 am by kjs »
« Reply #3 on: April 28, 2015, 12:31:16 pm »
I think i will use epoxy, and titen the nut down tight. These will be on the back of a piece of equipment,no frequent removals.
Offline smjcuk
« Reply #4 on: April 28, 2015, 12:45:00 pm »
I buy the ones with flanges on rather than relying on the D. You have to drill 5 holes but it's easier to work with and they stay put.
Online TimFox
« Reply #5 on: April 28, 2015, 09:20:13 pm »
If you drill a clean 3/8" hole, you can hit the panel just outside of the hole with a center punch and pick up some anti-rotation effect.
Offline babysitter
  • pushing silicon at work
« Reply #6 on: April 29, 2015, 05:22:01 am »
enclosure made of thermoplastic? Drill a tight fitting hole and use a relatively cool soldering iron to press some enclosure material back into the hole.
I'm not a feature, I'm a bug! ARC DG3HDA
