These things are all over Aliexpress, under the designation SSR-ddWA-R1, dd = power rating, e.g.
this one. However there's two issues with them, the first is that none of them indicate which of the two connections are the fire wire (= active) and zero wire (= neutral), every single diagram for them just labels them "a" and "b". Anyone know which is which?
The other problem is that they have to be wired between the power switch and the load rather than being made up into a general-purpose external soft-start controller that you can plug an arbitrary load into, because if they come before the power switch then they're permanently energised and won't ramp up the voltage when the load is switched on. This means you need to find space inside the device/load for a honkin' great piece of electronics.
You can also get these
dinky little three-wire things that'll fit inside most devices you want to run, but I'd hate to think what's inside those, maybe a single thermistor? The half-brick sized ones at least have potted power MOSFETs (according to one teardown) and a fair bit of thermal inertia.
