Author Topic: Is this MOSFET driver circuit ok?  (Read 5612 times)
Offline ChrissTopic starter
« on: January 12, 2020, 09:46:58 pm »
Hi!
I'm working on a small project where I have to achieve to control an injector solenoid with 3ms ON and 10ms OFF signal.
I should also have the ability to speed up and slow down the pulse but not to affect the 3ms ON time.
That part is ok for me, I did it with an Attiny85...
The input voltage is 12V and the injector consume around 2A current.
If this is needed.
What about I care, is the part where I drive the MOSFET.
Is this circuit good enough to handle the task?
Maybe some suggestion to improve this section or any other ?
I would appreciate any idea and help how to make my circuit/hardware more stable.
I have to say, I realized the whole project and it is working well, but I'm also wish to have some info from
you guys who are dealing with electronics design every day or from technicians who are more in this stuff then I.
Thank you very much.
My best regards.
Offline silverback
Re: Is this MOSFET driver circuit ok?
« Reply #1 on: January 12, 2020, 09:52:43 pm »
Hi, there should be NO connection between the opto coupler collector and the FET drain, turn off time can be improved by using an additional Zener in the fly back diode. This increases the voltage at fly back therefore reducing the off time.
The following users thanked this post: Chriss
« Reply #2 on: January 12, 2020, 10:05:39 pm »
Thank you for your time.
Can you pls show me maybe a right way how to connect the fet with the opto  the right way?
I'm also a bit confused with that part, so a schematic about how to connect it would be nice.
Thank you.
My best regards.
« Reply #3 on: January 12, 2020, 10:19:19 pm »
Ok.
I decided the collector from the opto to connect to the 12v but cut the trace between the collector and the fet. The LED2 would be still connected to the fet, to have a visual feed back about the speed of the fet on/off state.
Would this be a good mod?
Thank you.
Offline Etesla
« Reply #4 on: January 12, 2020, 10:54:10 pm »
I am not sure what you mean by connecting the LED to the fet, but the rest of it sounded OK. In an Ideal world I think your circuit would look like this.
Online Zero999
  • 0999
« Reply #5 on: January 12, 2020, 10:59:07 pm »
Why do you plan to use an opto-coupler? The MOSFET driving the solenoid is on the same ground as the microcontroller, so there's no need for isolation. All the opto-coupler is doing is slowing the switching down, especially the turn off time, with that 10k resistor. Get rid of it and connect the MOSFET gate to the MCU via a low value resistor, say 47R. The injector only uses 2A and the IRF1010N is capable of passing more than that, with a gate-source voltage of 5V.
« Reply #6 on: January 12, 2020, 11:01:54 pm »
Wow! Thank you for this.
I really like your mod.
The led you connected is really good, I was focused to get the signal to the LED2 from the fet,  but I like your design much more.
I'm already making the mod on the board... :-)
What would the best way to protect the MOSFET from short on the output?
Zero999:
I will try that too.
I was hoping the uC would be better protected if I use an opto, but as you wrote the fet and uC are on the same gnd, so the opto makes no sense anymore...
Thank you.
« Last Edit: January 12, 2020, 11:04:30 pm by Chriss »
Online floobydust
« Reply #7 on: January 12, 2020, 11:44:17 pm »
Just a few observations;
The LM7805CT has a minimum load requirement of 5mA and I'm not sure you have that?
ATTiny85 in a car, I use LP2950 for a 5V reg. I also add transient protection (series 1N4004, TVS) to the input at C1.
Best to look at a logic-level N-ch mosfet that is OK with 5V drive. IRF1010 needs well over 5V drive.
I also turn on internal pullups and have pushbuttons go to GND, to save a few parts.
You would want a fast-recovery diode across the solenoid, not a slow 1N4001. Like UF5404.
Offline DBecker
« Reply #8 on: January 13, 2020, 01:42:33 am »
Are you talking about driving an automotive high impedance fuel injector?
You don't want a freewheel diode.  That will unpredictably delay turn-off.  You want a protected driver with clamp.  The clamp will allow the voltage to rise to 40V-70V at turn-off, and then turn on the MOSFET slightly to limit the voltage spike.  70V is preferred for injectors, but a 40V clamp will work well.
« Reply #9 on: January 13, 2020, 06:55:24 am »
DBecker:
Yes, I wish to drive a car fuel injector, but only on the bench and nothing to do about driving or etc. with my design.
More to learn, designing, programming stuff...
I didn't understand correctly what you mean by the clamping circuit vs the fly back diode.
Can you pls give a circuit about that?
Thank you.
Offline magic
« Reply #10 on: January 13, 2020, 11:41:02 am »
Any particular advantage over using, say, a 55V MOSFET and letting it avalanche?
It's about the need to apply reverse voltage to an inductive load to stop current flow through it. This voltage is helpfully produced by the load itself when the FET turns off (the - connection to the load starts to rise above 12V) and the more you allow it to rise above 12V, the faster will the load turn off. The 1N4001 diode permits only about 0.7V.
« Last Edit: January 13, 2020, 11:44:32 am by magic »
« Reply #11 on: January 13, 2020, 01:21:55 pm »
Ok.
I understand now the clamping...
If I just replace the D1 with a fast recovery one, like someone wrote before, does that would be enough to make the proper clamping circuit?
Online Zero999
  • 0999
« Reply #12 on: January 13, 2020, 07:28:11 pm »
I agree it's not ideal, but it's rated for 60A and the original poster is only using it for 2A, which it can happily do, even with only 4.5V of gate drive.
https://www.infineon.com/dgdl/irf1010npbf.pdf?fileId=5546d462533600a4015355da754e188b
Ok.
If you want to turn the solenoid off as quickly as possible, then any freewheeling diode will slow it down. When the transistor switches off, the current keeps flowing through the inductor and diode. The voltage drop across the diode will be just over a volt or so, at 2A, so the current will decay very slowly. A zener diode in reverse parallel with the MOSFET will dissipate the energy more quickly than a free-wheeling diode. You need to choose a zener diode with a slightly lower breakdown voltage, than the MOSFET.
« Reply #13 on: January 13, 2020, 07:50:45 pm »
Ok.
What you mean by " A zener diode in reverse parallel with the MOSFET" the zen should be connected between S&D of the mosfet? Assume  not. Or?
Should I leav the D1 and add the zener in paralell with the mosfet S&D?
Thanks.
Online Zero999
  • 0999
« Reply #14 on: January 13, 2020, 08:43:22 pm »
The higher the voltage across the inductor, the quicker the current will decay. An ordinary diode  has a voltage drop of a volt, at high currents, compared to its rating, so the current will decay slowly. When the MOSFET turns off, the voltage on the negative side of the inductor is just a bit higher than the supply voltage. A zener diode clamps the voltage across the MOSFET to around 55V in this case, so the current falls more rapidly. The voltage across the inductor will be the zener voltage (the 1N5369B is a 51V, but the voltage is higher, at higher currents) minus the supply voltage.
« Reply #15 on: January 13, 2020, 09:46:31 pm »
I can say only big THANK YoU!
The diagram shows everything.
Thanks again to all of you to put me in the proper direction.
My best regards.
Online langwadt
« Reply #16 on: January 13, 2020, 11:19:02 pm »
Ok.
or depending on the rating of the FET skip the zener and let the FET do the clamping
something like a VND7N04 has clamping and temperature/short circuit protection
« Reply #17 on: January 14, 2020, 01:22:14 am »
Hmmm. This fet what mentioned the VND7N04 looks very interesting. I think I could save several parts with changing from my fet to the VND7N04.
Thanks for this info.
Offline DBecker
« Reply #18 on: January 14, 2020, 02:46:28 am »
You probably want something with a little more power handling capability so you don't have to be so careful with the gate voltage and heatsinking.  The VND14NV04 is an older part that is now inexpensive.  I recently bought a few on Aliexpress for 0.40 each.
Note that because the fault feedback shorts the gate input, it requires a resistor in series with the gate.
The gate is best driven with 5V, but it's still usable at 3.3V.
Offline MagicSmoker
« Reply #19 on: January 14, 2020, 12:37:33 pm »
I'd advise against this as not every FET is going to be happy with being repetitively avalanched, meaning a careless replacement could result in the immediate release of the precious magic smoke. Instead, replacing the freewheeling diode with a 24-36V bidirectional TVS* is a much safer alternative that will still achieve very speedy turn-off of the solenoid yet allow almost any MOSFET to be used in the circuit (well, any MOSFET with a Vds rating >50V or so, depending on what voltage the TVS clamps at, exactly).
* - e.g., SA24CA, SMAJ24CA, P6KE36CA, etc.
Online langwadt
« Reply #20 on: January 14, 2020, 01:47:23 pm »
And if you carelessly replace parts with random parts that happens to have the same number of pins the circuit might not work ....
Offline DBecker
« Reply #21 on: January 14, 2020, 05:53:55 pm »
A clamping driver, such as the OMNIFET parts mentioned above, does not use avalanche behavior.  It uses a zener diode from the drain to the gate.  This turns the MOSFET on to limit the inductive "kick" voltage.  It is more compact and effective than a traditional snubber circuit, and is much less sensitive to the load characteristics.
« Reply #22 on: January 14, 2020, 07:56:59 pm »
For sure guys I won't just pop out parts and replace them just so, I will check datasheets and infos about compatibility of the device and pinout arrangement etc.
But thanks for the precaution.
Reading your writings I slightly realized something what is maybe a better solution for my project than this what I built up and posted in my first post.
Maybe it is a better solution to avoid an active clamping circuit and using the avalanche behaviour of a proper mosfet.
I think from reading on the net and datasheets, to use the avalanche characteristic of a mosfet is more safer for the mosfet than to use an active clamping circuit.
From my perspective a mosfet which is suitable for driving inductive loads with internal protection etc. is a better option to use by me,
cos it is more precise calculated and built up compared to my calculations and maybe perspective of view.
Team of engineers done a much better protection and clamping for the specific mosfet than I can do as an average guy who has lot of electronics and programming knowledge but still not an official electronic engineer - part designer.
So, a mosfet let's say like the VND7N04 has a clamping circuit, a thermal and short protection circuit and a really dummi feedback but in conjunction with my dummy Attiny85 I could use that feedback to trigger an alarm and shut down immediately the circuit.
That sound so to me a more safer circuit than I did with all my mess of opto, clamping diode etc...
What do you think about this thinking path?
Maybe you can advice me a better or newer mosfet for my purpose?
btw. in what software was done that nice simulation what was posted by Zero999 ?
Thank you all of you for your time and help.
I learned lot of things from you.
My best regards.
Offline MagicSmoker
« Reply #23 on: January 14, 2020, 08:37:33 pm »
I didn't look up the datasheet for the above part, but my warning about not blithely relying on avalanching the mosfet with inductive loads applies to this as well: if a generic load switching circuit like this relies on a specific mosfet to not blow up then it's not a very robust design.
Erf, no, you got that backwards: only some MOSFETs are characterized for repetitive avalanche, and there are always strict limits on the amount of energy per avalanche regardless of whether it occurs regularly or just occasionally. My earlier suggestion to use a bidirectional TVS diode across the load (or the Zener across the MOSFET drain-source, as Zero999 shows) is the safest for both load and MOSFET, allows a wide variety of MOSFETs to be used, and enables much more rapid demagnetization of inductive loads than either a conventional freewheeling diode or the clever little MOSFET mentioned above that automatically turns itself back on when an inductive load "kicks" during turn-off.
P.S. - the simulation software Zero999 - and most of the rest of us here - use is LTspice
Offline DBecker
« Reply #24 on: January 14, 2020, 09:43:17 pm »
It's a very robust design.  It's one of the standard ways to drive an injector.
A protected driver is not just a MOSFET, it has additional functions. You wouldn't expect to substitute a simple MOSFET in its place.
The trend is toward using larger chips with multiple drivers and integrated diagnostics, such as the TLE8888 or L9788.  They all use similar clamped drivers.  You don't see 1990s-style discrete solutions.
