Author Topic: cannot identify this optocoupler  (Read 4241 times)
Offline EliminateurTopic starter
  • Country: ar
  • Electronic's Technician
« on: February 21, 2011, 07:16:35 pm »
i've been searching for quite some time for the datasheet for an optocoupler i have here, the markings are:
L 0625
817A
Y
i've searched 0625, L0625, 817, 817A, 817Y, nothing...
any ideas?
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: cannot identify this optocoupler
« Reply #1 on: February 21, 2011, 07:21:30 pm »
do you know the origin the the dvice it is in.
For example i have a medical device mad in Russia many years ago, It had some weird named DIP14 chips in it that turned out to be the russian version of the 7400
Offline Zero999
  • 0999
« Reply #2 on: February 21, 2011, 07:29:22 pm »
Yes the Russians copied many ICs from the US, including those used in some electronic games which amusingly exhibited the same bugs.
Do you have a picture of the PCB or a schematic?
Offline Bored@Work
  • Country: ar
« Reply #4 on: February 21, 2011, 08:19:06 pm »
Bored takes the jackpot!, i found a similar device datasheet but wasn't convinced, so yeah... run-of-the-mill optocoupler...
i wish i had an schematic!, it's from a Dell AC brick(which incidentally i have opened in another thread) that's misbehaving and i have no idea why
Offline Zero999
  • 0999
« Reply #5 on: February 21, 2011, 09:15:57 pm »
It's there to provide an isolated feedback path from the secondary to primary side and is unlikely to have failed so check out the other components before replacing it.
