Author Topic: Diy USB cable  (Read 5992 times)
Offline J.XerneasTopic starter
Diy USB cable
« on: March 01, 2016, 02:36:21 am »
I got tired of my cheep USB cables failing on me so I put together a beefy one with some spare parts I had lying around. I used 4 gauge stranded for 5v+ and ground, then I use 14 gauge for data. It worked excellent, I used it for a couple of months and then It was stolen. I didn't get a picture of it when I had it to post since I wasn't a part of this forum then. But you can imagine the sheer aw inspiring size of a 4ft USB cable made from 4 and 14 gauge cable. I actually am working on another one soon so I will post pics when I get them if I remember. I just thought I would share something a little different to get some people thinking.
It may have been overkill but it probably would have lasted a lifetime if it wouldn't have gotten stolen.
Offline JacquesBBB
Re: Diy USB cable
« Reply #1 on: March 01, 2016, 03:50:53 am »
AWG 4 is 21 mm^2 . Good for 60A+. Are you sure?
Offline relic38
Re: Diy USB cable
« Reply #2 on: March 01, 2016, 04:58:18 am »
60A on USB?  Cell phones in five years will need that to charge the 35Ah battery inside them :)
Offline KL27x
Re: Diy USB cable
« Reply #3 on: March 01, 2016, 05:52:41 am »
I take it that was a micro USB. For mini, I would have used at least 2 gauge.
Offline tooki
Re: Diy USB cable
« Reply #4 on: March 09, 2016, 10:12:21 am »
But usually what causes cables to fail is not the cable itself failing due to its gauge, but rather insufficient strain relief where it attaches to the plugs. Heavy cable only makes that worse, not to mention putting tons of strain on the connectors in the devices you're charging, due to inflexibility and/or weight of the cable.
Offline station240
Re: Diy USB cable
« Reply #5 on: March 09, 2016, 10:52:40 am »
hahaha sounds like my outdoor extension code made from 2+E cable (aka romex). Thing is it's got 10A plugs but 50A rated cable, I had to hammer the cables into the strain relief.
At the time we needed an extension cord for the cement mixer that would cope with being run over by wheelbarrows full of concrete.
Offline wraper
  • Country: lv
Re: Diy USB cable
« Reply #6 on: March 09, 2016, 11:01:40 am »
In regard to signal integrity, this sounds to be not better than crappiest non shielded Chinese USB cable. You need a controlled impedance and a shield, your cable does not seem to have any of these.
Offline Dave
  • Country: si
  • I like to measure things.
Re: Diy USB cable
« Reply #7 on: March 09, 2016, 11:10:04 am »
The cable did have shielding, he forgot to mention it. He wrapped a wire fence around it. :-DD
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline ericloewe
  • Country: pt
Re: Diy USB cable
« Reply #8 on: March 09, 2016, 07:57:00 pm »
The USB consortium got it all wrong! Instead of doing high-power charging using higher voltages, they should've gone with "MOAR CABLE!" and allowed for 60A charging.
Offline janoc
Re: Diy USB cable
« Reply #9 on: March 09, 2016, 08:11:55 pm »
I think that is meant for car cranking. Plug your smartphone in with some jump cords and poof, flat car battery is no problem!  >:D
Offline ConKbot
Re: Diy USB cable
« Reply #10 on: March 10, 2016, 07:20:14 am »
14awg stranded wire, with a 19 mil insulation and jacket(i.e. THHN with pvc  insulation)  twisted, but not perfectly tight together will come out to about 75-80 ohms. Being differential, and only a 4 foot run, it would probably work.
Not saying it's a good idea, but it's just a differential signal, not the boogey man.
Offline vk6zgo
Re: Diy USB cable
« Reply #11 on: March 10, 2016, 08:37:53 am »
The boogey man is never far from this forum. >:D
Offline ericloewe
  • Country: pt
Re: Diy USB cable
« Reply #12 on: March 10, 2016, 10:59:08 pm »
Somehow, that doesn't detract from the absurdity of the data pair supposedly being about as thick as the wiring to the 12V outlets in my car.
Offline sangvikh
  • Country: no
  • Join the resistance!
Re: Diy USB cable
« Reply #13 on: March 10, 2016, 11:06:13 pm »
Pics or it didn't happen!
Jumpstart wires for a usb cable?  :-DD
Offline dadler
Re: Diy USB cable
« Reply #14 on: March 11, 2016, 02:35:52 am »
I bet the thief stole it to recycle the copper.... Such is the risk in such a high conductivity USB cable. You've got to pay to play.
Offline ericloewe
  • Country: pt
Re: Diy USB cable
« Reply #15 on: March 11, 2016, 12:13:57 pm »
Maybe he thought it was the charging cable for his car.
Online Monkeh
Re: Diy USB cable
« Reply #16 on: March 14, 2016, 02:32:52 am »
I can't tell if this is a windup or serious.
Offline Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
Re: Diy USB cable
« Reply #17 on: May 13, 2016, 07:47:11 am »
need to make a non damageable cable?
ebay search for "Spring Coiled usb"
use the cable from result obtained in a midway joint...
that's how I do it,
My usb cable broke ,i turned it into extension chord and attached an above suggested cable to it as it is
Beware, the coiled cable usually comes with crappy plugs, you'll need to replace those
Offline Dave
  • Country: si
Re: Diy USB cable
« Reply #18 on: June 20, 2016, 03:09:27 am »
Pictures, pretty please. ;D
