Author Topic: Simple but powerful SAMD11 PCB  (Read 1089 times)
Offline Lt_FlashTopic starter
« on: September 06, 2019, 11:54:45 am »
This is my project of basic SAMD11C14 MCU breakout. It supports all required SWD pins, I2C, SPI and others and is very simple and straightforward to reproduce. SAMD11 is quite a powerful MCU and it comes in a great SOIC package that's very easy to solder. Please have a look at my project here and feel free to ask any questions!
https://workspace.circuitmaker.com/Projects/Details/LtFlash/SAMD11-Base-Board
P.S. Please read my comments on this project as you may want to add 1kOhm resistor on SWCK line and some PTC fuse if you're going to drain much current. Also remember, that MCU pins can provide only small amounts of current and you may need to use MOSFETs even to feed LEDs. Thanks!
