For my current project I needed an isolated supply for part of the circuit. So I got a couple of RECOM RBE-0505S 5V to 5V 200mA isolated DC to DC converters, same sort of thing in the Dave’s USB supply.
However I was concerned about noise for this application, and my investigation is the purpose of this post. All scope grabs are done a 100% output load.
So at full load with no output filtering at all, the following was what I got:
Having a look at the datasheet, that’s easily within spec, but not good enough for my application.
So I added some output capacitance, in this case a Nichicon 330µF 130m? 35V electro that I had plenty of. Also they were brand new from Digikey, so I knew they were the real thing. This decrease the ripple down to about 1/5th what it was:
At this stage the amplitude is pretty reasonable for a switchmode supply, about 0.22% of output. Also, what’s not evident from just the single scope grab is the ripple now gradually reduces as load decreases. Previously it has some weird things going on, particularly around 50mA. Further, the voltage regulation to load changes is much better as would be expected.
So next thing I did was to add a pair of ferrite beads in both the positive and negative lines, with 100nF caps either side. This greatly reduced the high freq components.
At this point, I thought I had a quite reasonable outcome, and it meet my requirements. However, I saw a damaged motherboard (written off due to physical damage in a move) in the corner that was loaded with polymer caps, so I pulled out the heat gun and stripped a few off it.
The ones I chose were 560µF 6.3V, and as you can see, they’re tiny! I set up my sig gen and scope to try and measure the ESR. I couldn’t do it accurately with this setup, but it was around 10m?. So I replace the electro with the polymer cap and removed the ferrite bead/ceramic cap filter.
As expected the output ripple is pretty low but there’s some high freq components they look pretty nasty. Adding the filter back in with the poly cap and this was the result…
Speaks for itself really, anything there is just noise in the measurement because I get the same result with the supply on or off. Down side is the poly caps cost almost $1ea, but it’s pretty awesome.
