Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Is there a bus protocol similar to CAN bus except with ethernet sized frames?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Is there a bus protocol similar to CAN bus except with ethernet sized frames? (Read 752 times)
e100
Frequent Contributor
on:
November 18, 2019, 09:47:47 am »
Not point to point like SLIP, but a multi-device bus.
In the olden days there was 10base2 over coax but that disappeared long ago. Is there a modern equivalent?
Last Edit: November 18, 2019, 01:41:26 pm by e100
Logged
HwAoRrDk
Super Contributor
Country:
Re: Is there a bus protocol similar to CAN bus except with ethernet sized frames?
Reply #1 on:
November 18, 2019, 10:44:08 am »
Well, there is CAN FD, which can have 64 bytes of payload data per message, but that is only equivalent to the least amount of data an ethernet frame can carry.
Logged
max_torque
Super Contributor
Country:
Reply #2 on:
November 18, 2019, 06:15:43 pm »
RS-485 with your own protocol / packetisation?
Logged
MagicSmoker
Super Contributor
Country:
Reply #3 on:
November 18, 2019, 07:04:29 pm »
There's nothing stopping you from using CAN (or RS-485) physical layer components and writing your own ethernet-like protocol. Whether the amount of work required is justified here I leave to you to decide.
Logged
rounin
Regular Contributor
Country:
Reply #4 on:
November 18, 2019, 10:07:10 pm »
Flexray is somewhere in the middle. 254 byte payload, looks to be time triggered instead of CSMA, ~10Mbps.
Last Edit: November 18, 2019, 10:08:58 pm by rounin
Logged
langwadt
Super Contributor
Country:
Reply #5 on:
November 18, 2019, 10:29:56 pm »
CAN and
https://en.wikipedia.org/wiki/ISO_15765-2
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
