Author Topic: LiPo charge in circuit 2S1P 7.2V stack  (Read 5291 times)
Offline SL4PTopic starter
  • There's more value if you figure it out yourself!
« on: April 12, 2014, 03:49:13 am »
I'm working on a project where I have to use 5V0 rather than 3V3 as Vcc
I could use a converter to push a (larger) 3V6 cell up to 5V/regulated, but would rather use 2x 2000mAh 3V6 Li-Xx cells to start high and regulate down.
Load is around 1200mA sustained from the battery pack, so a 500mA charge would be desirable.
All the integrated charger chips I see online are for single Li-Xx cells.
Does anyone have a hook into a multi-cell charger chip / schematic for cell balancing etc.
Batteries are not removable in this application (an IP rated hand-held enclosure)
--- or I could consider an OEM charger brick + cell kit that slides in to the handle like power tools. ??
Thanks
Don't ask a question if you aren't willing to listen to the answer.
Offline ohmineer
Re: LiPo charge in circuit 2S1P 7.2V stack
« Reply #1 on: April 12, 2014, 01:36:52 pm »
There are some integrated chips that charge 2S1P cell stack.
No sure if this is what you need but Take as an example these models:
- Microchip MCP7384X (http://ww1.microchip.com/downloads/en/DeviceDoc/21823D.pdf)
- TI BQ24133 (http://www.ti.com/lit/gpn/bq24133) and TI BQ24170 (http://www.ti.com/lit/gpn/bq24170)
Regarding to cell balancing, AFAIK it is not very used in battery packs with only two cells.
In any case, you can also take a look at BQ29200 (http://www.ti.com/lit/gpn/bq29200) model from TI.
Depending on the balancing current you want, the circuit can be very easy to implement.
Offline kaindub
« Reply #2 on: April 15, 2014, 03:39:17 am »
Hi SL4P
have a look in Silicon Chip magazine April 2014 (www.siliconchip.com.au)
I published a circuit that charges 2S Lipo from 5V (USB) and has cell balancing. Charging current is 250ma ( matched to the capability of USB ports)
You can adapt it to any input voltage and output current with a few component changes. Uses an MC34063 chip.
I designed it to be incorporated into equipment, similar to your needs
Robert
« Reply #3 on: April 15, 2014, 01:02:13 pm »
Thanks - both excellent refernces.
I was trying to get April SC - but everyone's out of stock.
Cheers
Offline amyk
« Reply #4 on: April 15, 2014, 01:11:21 pm »
Why is that? Parallel cells don't require any balancing (as long as they're balanced to start with, they'll stay balanced) and you'd have to use a boost converter anyway if you wanted to charge from USB (500mA).
« Reply #5 on: April 16, 2014, 01:00:05 am »
2S = serial
