Author Topic: Where to find this IDC socket?  (Read 3924 times)
Offline manuTopic starter
« on: April 15, 2014, 01:26:17 pm »
Hello,
I'm facing a problem to find a *female* right angled 2.54mm 34 pins (dual row) idc socket:
I know that it is more common to have a male connector for a board use, but I have to interface a National Instrument MyRio board (without a ribbon cable).
A potential reference is this 3M 5100 series: 5134-B7A2PL. But it's out of stock for a while... So if you have equivalent reference, please let me know!
Thanks in advance,
Manu
Offline fcb
    • Electron Plus
Re: Where to find this IDC socket?
« Reply #1 on: April 15, 2014, 01:39:47 pm »
most catalogue suppliers..
or go and have a peek at www.toby.co.uk
« Reply #2 on: April 15, 2014, 01:55:04 pm »
Thank you for this url, but it's pretty rare. I have already checked farnell, radiospares, mouser, digikey without success...
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: April 15, 2014, 02:04:36 pm »
Most suppliers will have something similar. BTW it is not an IDC socket -that may be your first mistake when searching.
If all else fails, Samtec make every permutation of header you can imagine.
Day Job: Mostly LEDs
« Reply #4 on: April 15, 2014, 02:29:09 pm »
Thank you for your tip!
Effectively, I have extended searches from idc to he10 and polarized key 2.54mm headers, and I finally found it after a few hours:
http://www.sullinscorp.com/category146/SFH11-PPPC-D17-RA-BK/
By the way, Mike, I like your videos!
Offline kizzap
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Offline Monkeh
« Reply #6 on: April 15, 2014, 11:56:38 pm »
If you'd looked at that link, you might have found: http://www.toby.co.uk/content/catalogue/products.aspx?series=B07a-xx-AGA1-G
Offline LukeW
« Reply #7 on: April 16, 2014, 01:14:05 am »
Try Digi-Key S5570-ND or S9207-ND, depending on whether you want the polarising key or not.
« Reply #8 on: April 16, 2014, 06:38:31 am »
Hello,
Thank you all for these helpful links.
this was all I could find:
http://au.element14.com/samtec/ssw-117-02-t-d-ra/receptacle-2-54mm-tht-r-a-34way/dp/2308490
I found this one too, it seems that Samtec doesn't make polarized sockets.
Ok, in fact I checked your link but I missed this section. Thank you, it is a possible second ressource.
Yes, it seems that only Digikey can distribute Sullins. As it is one of my favorite suppliers, I'm gonna order Digikey this part.
