Hello EEVblog! I have a question about a current project I am working on. I have designed my first pcb based on the attached schematic, and after ordering and assembling the boards, testing is not going as planned.... First a quick rundown of the schematic.
I am using a FT230x chip in conjunction with the max203 rs232 transceiver in order for serial data from a separate PCB can be read by a tablet application.
The issue: When plugged in the tablet recognizes that a USB device has been plugged in but there seems to be no data being sent from the tf230x chip to the max203 transceiver. The RXD and TXD lines have no data and are defaulted to 5v and 3.3 v respectively.
I am not sure why this is, but I have a few culprits, with one being that I am not using the RTS and CTS pins of the ft230x chip, and the datasheet seems to not go into much detail about the implications of leaving them floating would be. I also did not include 10k pullup resistors to vccio on the RXD and TXD lines which could be causing an issue as well. There seems to be no other issues in terms of unconnected power traces and the internal charge pump of the max203 chip seems to work as well. Maybe these arent the issues at all and I should try a redesign of the schematic and board entirely. I would just like someone more knowledgable than I am to help, thank you!
