Hi All
Got a product that I purchased that didn't have the POE option installed so I would like it to have POE.
started with measuring the rail voltage (5V) and purchased this 5V RT5400 POE module
https://www.aliexpress.com/item/1005006181940528.html?spm=a2g0o.order_list.order_list_main.17.4d91180264P9zPI have done this to a similar product made by a different manufacture and it worked perfectly
Photos attached of product trying to add module too
Soldered in the POE module and the device does nothing.
Directly powering the 5V rail results in a dead short across the rail
Desoldered the output side of the module and measured the output pins of the POE module and nothing 0V.
The switch doesn't detect the device in any way either.
Have swapped module with another one
Have tested ethernet with the other manufactures device with the same POE module and it works
Have tried soldering different resistors on the pads on the input side haven't found a value that would do anything
Any ideas of getting this to work will be great thanks
