Author Topic: Reliable source for micro HDMI Male PCB mount connectors??........  (Read 4017 times)
Offline SmokeyTopic starter
  • Not An Expert
Something like this would be perfect:
Surface mount is fine too.
All I can find is Alibaba sources.
This is one of those problems I did not expect have, but unless I'm doing something stupid Digikey/Mouser have nothing like this.
Thoughts?
  • Not An Expert
Re: Reliable source for micro HDMI Male PCB mount connectors??........
« Reply #1 on: November 28, 2023, 12:51:38 am »
No male micro HDMI love?   Do they have too much toxic male connector masculinity?  They are "micro" connectors, so they are probably going to be compensating for that.... :)
The following users thanked this post: wasedadoc
Offline Someone
    • send complaints here
« Reply #2 on: November 28, 2023, 01:37:55 am »
It's like trying to find PCB mount male BNC, they exist, they are made in reasonable volume, but are not stocked in regular wholesale/retail.
If you need reliable volume, go ask the manufacturers. Small volume, one time buy of mystery grey market stuff.
  • Not An Expert
« Reply #3 on: March 03, 2024, 07:36:40 am »
This came up again... who's going to be my new personal hero?
(Ideally something with a datasheet that actually has a mechanical drawing for the pins)
« Last Edit: March 03, 2024, 07:39:03 am by Smokey »
Offline bakulapal
  • Country: hu
« Reply #4 on: May 24, 2024, 07:50:57 am »
This one looks like similar to what you are looking for:
https://bossconntech.com/connector/micro-hdmi-hdmi-d-type-connector/micro-hdmi-male-connector-clamp-board-type.html
I also found a Molex part but it's not a publicly available part.
« Last Edit: May 24, 2024, 08:00:00 am by bakulapal »
Online wraper
  • Country: lv
« Reply #5 on: May 24, 2024, 08:28:22 am »
In the past I found that male video connectors (HDMI, DP and more so micro HDMI) are either not sold by western distributors at all or barely any for ridiculous price. So if you cannot find what you need at LCSC, your only options basically are aliexpress or alibaba, ordering direct from Chinese manufacturer.
« Last Edit: May 24, 2024, 11:15:38 am by wraper »
Offline djawahar
  • Country: in
« Reply #6 on: May 28, 2024, 03:56:50 pm »
Hi, I'm also having the same issue. Did you find any reliable distributor for Micro HDMI connectors?
  • Not An Expert
« Reply #7 on: May 28, 2024, 08:29:17 pm »
Nope.  I ordered some samples from Alibaba.  They showed up.  That's about all I can say at this point.  I haven't finished the project yet so I can't say I have a good working solution yet.
