Outside of design:
You are merely verifying operation. You'd have to analyze the design* to know how much ripple is intended or acceptable.
*Lord knows, no one ever writes design documentation, even within the hushed confines of NDAs and whatever background data a project might have. (I've done it only a few times myself, and have yet to see it actually requested for a project.)
So, setting that trigger, measuring what the ripple actually is: not very meaningful in general.
Much easier to guess that the design intent includes component selection, and verify the components. Namely, look up the capacitors (say) and see what tolerance and ESR they were supposed to be, then measure their value (out of circuit if necessary). Don't forget to check under suitable conditions, e.g. ESR might be fine at room temperature, but it goes out of spec at high or low temp (minding that the spec is normally several times higher at low temps; more than that would be out of spec).
