Author Topic: Non EE question...screwing plastic parts  (Read 625 times)
Offline Gibson486Topic starter
« on: February 16, 2021, 05:02:16 pm »
Is there a pre tapped bushing you can buy so I do not have to tap plastic for use with screws? if so, what are they called?
Offline Andy Watson
Re: Non EE question...screwing plastic parts
« Reply #1 on: February 16, 2021, 05:09:53 pm »
Search your favorite providers for "plastic inserts".
Offline penfold
« Reply #2 on: February 16, 2021, 05:13:56 pm »
Threaded bushes or threaded inserts normally gets you some results, cold press, barbed and heat settable varieties exists depending on your need,
For hobby purposes you can get descent results with "thread repair inserts" and "NUTSERTS" and a bit of creativity
« Reply #3 on: February 16, 2021, 05:44:06 pm »
Thank You! I just googled plastic inserts at first....did not occur to me to add "threaded"! :-DD
Online TimFox
« Reply #4 on: February 16, 2021, 05:54:30 pm »
McMaster Carr has a wide range of threaded inserts designed for plastic:
https://www.mcmaster.com/threaded-inserts/for-use-in~plastic/
There are also clip-on nuts that might be suitable, depending on your application:
https://www.mcmaster.com/clip-on-nuts
Offline ConKbot
« Reply #5 on: February 16, 2021, 09:13:37 pm »
There is also self tapping plastic screws, if you don't need something as durable as an insert.  McMaster has them under "plastite screws" they are self tapping, and have a rounded triangular cross section that is less likely to back out, they work well in my experience. Just make sure to stick with inserts and machine screws for battery doors ;)
The following users thanked this post: jbb
