Hello all,
I have also some analog multimeters, that I'm using from time to time. I have 3 different types:
a: Metrix 202 B
no battery needed, if you do not use Ohms range good DC accuracy. Good for DC voltage and current, not the best for AC. my first multimeter I ever worked with.
b: Philips PM2505 electronic VAOhmmeter. It has a linear Ohm scale, really great! I love it. nice span of different ranges. 10MOhm input impedance.
c: Philips PM2504 electronic VAOhmmeter, bench top type. It has a also linear Ohm scale, and compared to the PM2505 a few more ranges. It has also 10MOhm input impedance.
From the Metrix I have a few. Sometime it is good to use them, e. g. if you measure the current of a PCB in different operating modes. You'll see very good a trend, if a measurement increases or decreases, mutch better then the modern digital ones with a bar-graph display.
I like of the Philips meters especial the DC ranges, as you do not meed to use the correct polarity for your measurement, they have a 2nd small instrument, indicating the polarity of the DC voltage or current.
Guido
