Curious as to whether there are intrinsically high-voltage indicator LEDs on the horizon. As voltages rise above 12 V, a resistor current-limiter becomes less and less efficient with most of the energy being expended by the resistor. LED drivers, which are basically current-limited PSUs, are more efficient but add expense and bulk. Capacitor-based current limiters for AC aren't really better than a LED driver. After an AC safety capacitor, reverse current diode, fuse, bleed resistor, and in-rush resistor are added, cost and bulk approach that of a solid state driver.
So it would be great if there were LED's or other light-emitting chips that could be used directly with 24, 120 or 240 V. There are some flat LED's designed for overhead lighting that can be used with 60 V. Seoul's MJT type is an example, and internally is effectively a bunch of LEDs in series on one chip. What are the prospects for a low light output, low current, cylindrical 3-5 mm or smaller form, the type used as indicator lights as opposed to lighting?
Mike in California
