Just for fun, I bought a JYE Tech DSO150 oscilloscope from Banggood. I thought it would be a fun soldering project that might be usable sometimes.
When it arrived, I read the instruction, which says to verify that it boots before soldering anything. Else the warranty will be void. I found a 9V power supply with center positive as instructed.
I connected the power. The screen gets light, but nothing happens. After a while, I smell that something is getting hot. I remove the power and can feel that the large IC is really hot. I first thought the power supply might be faulty. So, I connect my power supply instead. Exactly 9V. I didn't think to turn down the current limit on the supply. After turning it on, it lights up exactly like when I used the power supply. Light screen, and a red diode on the backside. Then I notice that it delivers 1.5A through the circuit, and I see some smoke after a few seconds. According to the manual, it needs 400mA.
I reported this to both Jyetech and Banggood. Jyetech send me a replacement. Banggood sent me another complete kit because I had received a bad unit.
The new ones arrived yesterday.
I first tried the one Jyetech sent me (with the same power supply as last time - I have verified it since). Lo and behold, it boots up, and the screen looks as expected. I try the same thing with the other one, but it's as dead as the first one I received.
I now try the Jyetech one once more, and now it won't boot again...
So, I set up my power supply again. This time, I use the current limiting. I set it at 200mA first. I test all three boards, and none work. I up the current to 400mA. Now the red diode glows dimly on one, but not on the others. I up the current to 600mA, and now the red diode shines brightly.
As I didn't have a schematic, I did do some measuring.
The input is 9V, and then there's a voltage regulator which outputs 3.3V. There is a pad that says 3.3V. This looks like a good spot to measure the voltage. I can see no consistent results between the three boards. None of them measure 3.3V there though.
Using the continuity tester, I see that there is a short between all legs of the voltage regulator and ground on two of the boards. The third has 174 ohms between ground and 3.3V, while the others have 0.5 ohms (or thereabouts). Clearly, there is a short somewhere, that makes the voltage regulator get hot.
On one of the boards, it's the big IC that gets hot, while on the other two, the voltage regulator gets hot...
Anyone else with this problem? I seem to find a number of positive reviews of this unit.
[edit: I removed the negative comments. I understand more of the circuit now, and believe the margin for over-voltage wasn't enough. Many power adapters give out much more than 9V when unloaded. The voltage regulator only handles up to 15V. They are going to release a new version with a 5V USB power connector instead, which will make for a better tolerance to over-voltage]
