Those circuits are good, with one mod: I would include hysteresis, at least on the "fancy" transistor'd versions. 10mV back to Vref or the "anode" (whichever is easiest and works correctly) would be enough. That way you don't risk malfunctions on slowly rising supplies.
TLV431 is 1.24V, so there's that. There are chips of various flavors with internal references from 100 to 800mV, though they obviously(?) require additional voltage to function.
You need at least 0.8V to guarantee SCR turn-on, and about as much to maintain current through it as well.
A MOSFET can pull down lower, but requires positive gate voltage. Or if you're lucky enough to find a depletion mode device or JFET that big, but...beats me if such is available. Even so, you would then need a substantial negative supply to provide reverse bias when it's supposed to be off.
If you can have a bias supply for it, it'll do well. The purpose of a crowbar is to shunt *excess* power, which implies you have an excess available somewhere..
