That design reminded me of Daves PSU alright, not that its a bad thing since he did a great job on it.I especially like the switchmode tracking preregulator.
Yes, I liked Daves design a lot. Thats why I took it as starting point.
One thing i noticed tho is that you should put a RC filter on your control voltage from the DAC because the MCU is noisy and could make the control voltage noisy, that then results in the output having extra noise.
You are probably right. What values would be right for that filter ? (1k / 0.1uF)
If you want it to work better at very low voltages you could replace that current source with your own. Put a small cheep mosfet on the output that goes to ground trough a 1 ohm sense resistor and then use a opamp to regulate the voltage across the resistor. Because the opamp can have its own supply that should be able to sink the current down to 0.1V or even lower.
For now I decided to live with the limitations in that area. It is quite rare that one needs very low voltage and current at the same time.
The USB isolation is a bit more complicated to solve but you can do it if you go get a FTDI USB to UART chip and then run that to the MCU over a optoisolator.(Btw Microchip makes the MCP2200 that does the same thing as the FTDI chip but is at half the cost)
I also decided to leave USB isolation off. I have two lines of thought: 1) If you need isolation, then you can connect via bluetooth. 2) If I can get the switcher to start working at 5V, then I can use USB as a power source, this would be a great auxiliary functionality. Of course, there would be power limitations and probably no LCD backlight.
Cons:
- seems you skimed on the feedback pin stability :/ neither of your regulators have any capacitance on there feedback pins, (1u perhaps?)
You talk about the 'Set' pin of the LM3083, or the input pins of the opamps ?
You are right, the 'Set' pin should get a cap.
- on your switcher disable jumper i would like to see more than 1 via for 3A :/
You are right, I've rearranged D21 and R26 and don't need the vias anymore as I can stay entirely on the top side. In earlier designs I had four smaller resitors in parallel in place of R26 and I started out with all resistors at the top. Now it is much better :-).
- output jumper too close to p62,
Yep, moved it.
- sil sockets are generally only rated to 1A per pin,
Yes, I know they are a bit too small. Have a good suggestion ?
Also, the input barrel connector has the same problem. Connectors rated for 6 amps exist, but are very expensive.
- same problem faced with daves design, for true almost 0V operation needs a diy current source, ($3 seems to not being doing anything important)
As I said, I decide to live with the limitation of the design for now. If I come across another good regulator design I like I will replace that part. Richard (amspire) went on to design something, but what he came up with would mean 20-something parallel transistors, the does not appeal to me.
Pros:
- the 22uF caps with the 0.025 ohm sense resistors make a great low pass filter for the switcher, took me a while to work that one out,
This is not really intentional, but an artifact of the current sense resistor where it is.
- love the test point branch outs, would prefer the power supply region ones to actually be plated holes, but that is a request,
This is a prototype and designed to tinker, so accessible test-pints are a must. I could replace them with a single pin sil, to get a plated hole.
- like the way your smd parts are well spaced,
I have enough space and will assemble by hand, so as well use it to make it easier for me. Also, I started out with 0804 and went to 0603 later (components are cheaper and there is more variety).
Thoughts:
- why is C2 0.33uF and not a 1uF like all of your other regulators use?
That value comes straight out of the data sheet of the regulator. Also that cap is in parallel to C1 (but ceramic), so capacity is not a concern. It also has to be of higher voltage that the 1uF caps (50V instead of 10V), so it has to be a different part anyway.
Other thoughts:
I don't really like the way I supply the 6V and 3.3V power. I burn up to 1W there, but am not keen on using a switcher. I'm contemplating to remove the 6V regulator and supply the LEDs, backlight and uCurrent MOSFET directly and regulate the 3.3V also from the input voltage.
This would also open up the possibility to use the USB 5V supply as input voltage, if the switcher works down to 5V. I just have to device a good way to switch to the USB supply, if the main input voltage is missing, this without loosing much of it (no diode) and being sure not to send 12-20V down the USB line, when both are connected.
Thanks for the thoughts, helps me to proceed !
